Like Tree27Likes
Old 09-15-2015, 05:43 PM   #16501
edonsohc's Avatar
by switching to the front 12mm spindles, either exotek or the b5 version, u have to run the st or sc hubs. the st/sc hubs put the spindle farther back and up. what does that do as far as setup and handling?
Tekno sct410.3, tekin gen2 rx8, hobbywing 4700kv motor, savox 1258.
Tekno EB48.3sl, 4000kv hobbywing on 3s.
Losi scb, mmp, bhr 10.5 motor.
Ofna H4E, vta, usgt, & 17.5 tc
Spratt's Hobby Center, Hillsdale Michigan.
edonsohc is offline   Reply With Quote
Old 09-15-2015, 06:18 PM   #16502
ekt
ekt's Avatar
If I remember correctly, the ST/SC hubs put the axle in the '3' position. It's less aggressive than having the axle further forward, according to TD's insert article http://www.team-durango.com/ttt-arti...rticle_id=4518
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 09-15-2015, 06:23 PM   #16503
I used the sc hubs and axles to run hexes and it works fine. I think the axle ends up where most would want it anyway.
Roken is offline   Reply With Quote
Old 09-15-2015, 08:52 PM   #16504
Trader Rating: 21 (100%+)
I think so too.... Grab yourself some truck hubs and B5 front spindles and you're done. I use 4 spacers just like you run 4 trailing... It's perfect
AE B6
AE B64
kerby is offline   Reply With Quote
Old 09-16-2015, 12:17 AM   #16505
windstar's Avatar
Originally Posted by Devin View Post
Anyone race on indoor carpet? I tried a couple times last winter and this time I will do a full change-over for my outdoor set-up.
Anyone have any ballpark ideas on what pinions and spurs I may need?
Pinions for:
1) The SCT has a 17.5 blinky class so I will do that
And Pinion gearings for:
The ST and buggy classes run a 13.5 blinky / open 17.5 class (it's the same class - they run against each other). Any idea on the gearing options for these
2) 13.5 blinky
or my other option
3) 17.5 open
I race also with 13.5 blinky (carpet outside) and use 87 Spurgear, 28 Pinion so it's a 8.07:1.
There is no bigger Pinion possible at that point. For next time I will get me a smaller Spur about 80, so there is more space for other gear ratios. The Motor gets about 60 degrees Temperature at this Point and the Buggy is MM3 build.
windstar
No TC at the moment, Team Associated RC5.2 x 2, Tam Associated RC10 B6, T.O.P Racing Rebel 12 (2013), VBC Lightning 12M, Sanwa M12
windstar is offline   Reply With Quote
Old 09-16-2015, 02:11 AM   #16506
ekt
ekt's Avatar
Pinions for:
2) 13.5 blinky
or my other option
3) 17.5 open
For 13.5 Blinky, I would try 69/26 as a starting point. For an idea where to start with gearing, check out http://durangofansite.com/main.php?v...0&page=gearing
Leo Lorenzen
Old 09-16-2015, 07:30 AM   #16507
Devin's Avatar
Sweet thanks guys.
I have read that 17.5 boosted is faster than 13.5 blinky... Deciding if I want to mess around with that. I do like the simplicity of blinky.
I could not tame my DESC for the life of me last year. Thinking of switching it to rear motor. Is rear motor really that slow on carpet compared to mm?
Devin is offline   Reply With Quote
Old 09-16-2015, 08:18 AM   #16508
edonsohc's Avatar
thanks for the link. it's very informative. I bought the buggy used and it looks like the front on mine was not in the stock location. I'll switch it and give it a try.
Old 09-16-2015, 09:48 AM   #16509
asalas's Avatar
Send a message via Skype™ to asalas
Default Follow up
Originally Posted by Jeff Werner View Post
Have a dex210v2 that I am needing a new body for. Does the td402014 fit the v2?
Thanks.
Hi there, did you manage to find a body? If you found a body please let me know where.
The v1 body doesn't fit the on the v2 chassis and I tried finding a v2 body but it seems that nobody in the world has them in stock.
A friend of mine is selling me a v2 spare body surplus to his needs but I'd like to get one more.
Cheers
asalas is offline   Reply With Quote
Old 09-16-2015, 04:28 PM   #16510
Laker67's Avatar
Trader Rating: 63 (100%+)
Jconcepts still makes a body for the 210, I believe this is the body that Amezcua runs on his 210: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBWVT
Thanks to my sponsors: Maclan Racing, Addiction RC, Exotek, Jconcepts, Futaba, and Trakpower
Brian Jenkins
Local track: Addiction RC in Ogden, UT - AddictionRC.net
Laker67 is offline   Reply With Quote
Old 09-16-2015, 06:03 PM   #16511
Kremzeek's Avatar
My wife has that on her dex210v1. I don't think it will fit on the dex210v2 with its +8mm chassis
Kremzeek is offline   Reply With Quote
Old 09-16-2015, 07:16 PM   #16512
asalas's Avatar
Default Dex210v2 body
You are right, the extra 8mm and the shape of the side pods (smaller on the v1) would make it unsuitable for the v2 chassis.
Has anybody tried the v1 side pods on a v2 aluminium chassis? Maybe that would work with the concepts body??????
Thanks guys
Old 09-16-2015, 08:33 PM   #16513
Laker67's Avatar
Maybe a little extra cutting to make it fit then?
Brian Jenkins
Old 09-17-2015, 05:44 AM   #16514
ekt
ekt's Avatar
Thanks guys
The holes for the side pods on the v2 chassis are in different positions compared to the v1.
Leo Lorenzen
Old 09-17-2015, 07:29 AM   #16515
Laker67's Avatar
HAHA touche, well I concede I just noticed that's the body he runs. I haven't tried it yet so I don't know first hand how he did it. Especially with the side pods be as different as they are.
Brian Jenkins
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
