Like Tree26Likes
Old 08-22-2015, 11:19 PM   #16441
windstar's Avatar
Default Noisy problem on v1
Hi,
I got a used v1 in mm4 build, put the electronic in it and went to a race.
In left corners there is a noise out of the back. A friend with the same car in mm4 has the same issue. Is there anything to solve the problem?
TIA
Ivo
windstar is offline   Reply With Quote
Old 08-23-2015, 01:45 AM   #16442
Originally Posted by windstar View Post
Hi,
TIA
Ivo
Hi Ivo,
especially in fast high traction corners, on carpet tracks
who has a idea whats grinding in the buggy
cu
Boris
sirob is offline   Reply With Quote
Old 08-23-2015, 05:05 AM   #16443
RC10Nick's Avatar
The v1's have shorter diff outdrives. If the car is rolling enough in the corners, there could be an issue with the cvd's trying to pop out of the outdrives. You could try reducing droop in the rear to see if it fixes it.
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 08-23-2015, 05:29 AM   #16444
ekt
ekt's Avatar
Is it possible your wing is rubbing on your tires? That will make a screeching noise around corners.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 08-23-2015, 10:12 PM   #16445
windstar's Avatar
Thanks for all the ideas.
Yesterday I build it MM3, so next time running it, I will see (better hear) if it's solved with that funny noise.
Oh btw. - I have 50 Gramm in the back of the car, and together the weight ist 1740 Gramm.
So where can I save weight without big differents of driving?
At the race it was very good. What Setup will be ok with less weight and MM3 on high grip Carpet?
windstar
No TC at the moment, Team Associated RC5.2 x 2, Tam Associated RC10 B6, T.O.P Racing Rebel 12 (2013), VBC Lightning 12M, Sanwa M12
Old 08-24-2015, 03:48 AM   #16446
Trader Rating: 21 (100%+)
If you're running stock...consider a Dimec20 composite chassis
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 08-24-2015, 10:39 AM   #16447
A shorty Lipo will save you about 80 grams. It will also move your balance point closer to the back of the car so you won't need to put as much weight in the rear.
jha07 is offline   Reply With Quote
Old 08-24-2015, 11:11 PM   #16448
windstar's Avatar
Thank you so far.
Where do I get Dimec20 Chassis?
I do ask for the Price of a Shorty. Sounds very good :-)
The Chassis is TD320229 ... I found it :-)
windstar
Old 08-25-2015, 02:03 AM   #16449
ekt
ekt's Avatar
Thank you so far.
There are two different version of the composite chassis, the more flexible DIMEC TD320229 and the stiffer DIMEC20 TD320247.
Leo Lorenzen
Old 08-25-2015, 09:55 AM   #16450
Dino_D's Avatar
Dimec is for low grip and low temps, Dimec has less flex for high grip or high ambient temp.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 08-25-2015, 10:08 AM   #16451
Trader Rating: 20 (100%+)
So your noise issue went away when you switched to MM3? I have mine in MM4 and it often makes a squeak-chirp sound, especially when it launches off jumps at the track.
chadp is offline   Reply With Quote
Old 08-25-2015, 10:12 PM   #16452
windstar's Avatar
I didn't drive yet, but I let you know if the Sound is away after building MM3.
windstar
Old 08-27-2015, 10:06 AM   #16453
Laker67's Avatar
Trader Rating: 62 (100%+)
delete
Thanks to my sponsors: Maclan Racing, Addiction RC, Exotek, Jconcepts, Futaba, and Trakpower
Brian Jenkins
Local track: Addiction RC in Ogden, UT - AddictionRC.net
Laker67 is online now   Reply With Quote
Old 08-29-2015, 07:24 PM   #16454
So I put all the V2 parts on my V1 chassis, will take it to the track Wed. Running it in stock class. Any advice or comments welcome.
sgtlt is offline   Reply With Quote
Old 08-30-2015, 10:32 PM   #16455
Airlmeier4422's Avatar
Hey guys, looking for a mid motor setup help/suggestion. All year I run rm3 with great success (won the points series), but many of the fast guys run mid motor (rb6, b5m and serpent). Now the kicker is the track I run on is loose/semi loose with a few decent size jumps and semi bumpy. In the main groove its semi etc. We water and broom the track off between rounds and at night the moisture will actually stick around. We are currently starting a mid motor class for fall series (they are jealous I beat them). Im looking for guidance to gain as much traction possible. Ill post my setup sheet (have not changed the car yet this is just guessing). Let me know what you all think. Have advice, please offer it.
Anything in YELLOW I am undecided on.
Tires are not really issue. Best tires at our track is SS impacts, hybrids, enduros and holeshots.
Thanks peeps.
Airlmeier4422 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
