Like Tree26Likes
Old 05-02-2015, 06:50 PM   #16276
Lone Star's Avatar
Originally Posted by Cain View Post
Where ar you guys finding really small spur gears that are not avids?
We opened up some practice for stock buggy class and Dinos setup for outdoor felt really good on my DEX V1 which is using the Dime chassis
The main issues I had were:
- not enough gearing range, was running 34 / 69 and felt like I wanted a bit more top end
- Track conditions went watered would cause front droop screw perches to pack and I would loose travel on the front suspension, do people do a mod here?
- WHERE ARE YOU GUYS FINDING the 25 Degree caster inserts? I have the right part # NIB but no "zero" insert to get 25 degree caster. was this a new running change?
I would like to keep running the exotek gear cover if possible so finding even smaller spurs would be great.
Here is what the track looks like I am running on for conditions (the video) and current layout (the picture):
+ YouTube Video
current layout:
The spurs I run are reamed out AE and Jcon. Take the rear 0' insert and cut it down to get 25' in the front. I think Shuey spurs also fit without mods.
Lone Star is offline   Reply With Quote
Old 05-02-2015, 08:19 PM   #16277
ekt
ekt's Avatar
+ YouTube Video
current layout:
Other than Avid spurs, using the Exotek slipper eliminator is the other way to use smaller spurs.
Some people cut off the droop tabs and use limiters in their shocks to get around dirt altering droop.
The '0' inserts were a running change. Cutting down the rear hub inserts is an option if you have older stock. http://www.team-durango.com/blog/201...B0-caster-mod/
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 05-03-2015, 12:09 PM   #16278
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
okay thanks when you ream them what are you using and how much are you taking out.?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 05-03-2015, 07:10 PM   #16279
Lone Star's Avatar
I have a step reamer and clamp them in mill or drill press after centering. The final hole is a 8.019mm.
Old 05-04-2015, 04:44 AM   #16280
I use AE also but I used a dremel and hold it my hand. I've messed 1 up but the rest are good!
iceman_bigb is offline   Reply With Quote
Old 05-04-2015, 08:11 AM   #16281
rc_dude's Avatar
Trader Rating: 130 (100%+)
Hey guys, I've seen some people running mid motor with a rear weight on the back of the tranny. I can't find these weights, do you guy know where to find and buy them?
Just decided to rebuild my buggy as mid motor
Engineering is my passion.
Team Durango ET48.3, EB48SL, & DEX408v2
One of a kind vehicle in progress
rc_dude is offline   Reply With Quote
Old 05-04-2015, 08:24 AM   #16282
hacker's Avatar
Trader Rating: 140 (100%+)
http://www.amain.com/rc-cars/revolut...rp0049/p231383
hacker is offline   Reply With Quote
Old 05-04-2015, 08:24 AM   #16283
Tech Legend
Cain's Avatar
here is one:
http://www.amain.com/rc-cars/revolut...FZCLaQodaTAA6g
The one I am using is shorter I believe an slightly lighter.
Old 05-04-2015, 12:34 PM   #16284
Dino_D's Avatar
Normally if you want more power in stock class, try turning the endbell to somewhere near 25 to 30 degrees if you are running blinky. Or use a high torque rotor, which will allow you to gear even higher.
I never had the droop screw perch pack, but you can always use droop limiters inside the shocks instead and cut the ears off the front. try 2mm limiters inside the front shocks.
The insert is a running change and now comes with 0 inserts for the front.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 05-11-2015, 02:50 PM   #16285
Default Gearing17.5 turn
Looking to get more speed out of my 210 with 17.5 (class rules at track) or any other tips for more speed? Thanks
Team Durango USA
OS Engines
Iggy 102 is offline   Reply With Quote
Old 05-11-2015, 04:06 PM   #16286
Tech Legend
Cain's Avatar
what you running for gearing now?
Runnng 17.5 myself as well, so curious anything you find.
Old 05-11-2015, 05:57 PM   #16287
theclutch's Avatar
Cheat... Oh wait, did I say that out loud?
When you say "get more speed", there are a few interpretations to this. First, are people blowing by you on the straights? If so, then you surely need more speed assuming they are also running a true "blinky" 17.5.
If you're saying your times are slow, then the setup of the car and your driving skills come into play.
Assuming it's the first situation, the only way you can get more speed is:
1) add more gearing. But if your motor is getting too hot (150-180F is what most people say is the limit), then you are over geared already. Also, even if your motor does not get too hot, gearing too much will lose you punch in tight tracks where there will be a lot of stop/go. So don't sacrifice speed through the corners for top speed in the straights.
2) get a better battery. In offroad 17.5 (doesn't matter much in onroad) you will want more punch out of the batteries. Thus, a higher C rating battery will do wonders.
3) lighten the car. This is assuming you are over the weight limit. Getting the car to the lowest weight allowable will get you the fastest possible top speed.
Other than the above, you'll need to work on your setups and driving to go "faster".
Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 05-11-2015, 06:23 PM   #16288
Running 87/26 now
Team Durango USA
OS Engines
Old 05-11-2015, 07:18 PM   #16289
hacker's Avatar
Run 69 spur. I'm running 33 pinion
Old 05-11-2015, 07:46 PM   #16290
So your saying run 69/33?
Team Durango USA
OS Engines
St Ives RC Club B4Bandit Australian Racing 16570 09-23-2017 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
