Like Tree26Likes
Old 04-01-2015, 05:26 PM   #16246
theclutch's Avatar
Originally Posted by rcjunky1 View Post
The slipper spring makes that impossible
Doh! You're right... I don't know what I was thinking... must have gotten confused with my other cars.
Originally Posted by Dino_D View Post
When a hobby shop orders a bunch of bearings, they come in plastic tubes. Some tubes actually fit around the slipper nut and it has a cap that you can remove when you need to adjust the slipper nut.
That's a darn good idea!
Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 04-04-2015, 08:33 AM   #16247
has someone the chassis in cad
Kutel is offline   Reply With Quote
Old 04-05-2015, 02:47 PM   #16248
I am getting a used dex210 with motor mounted rear. Are there any parts that would not be on the car that would be needed to mount it mid? Thanks
Canuck5902 is offline   Reply With Quote
Old 04-05-2015, 03:43 PM   #16249
303slowdown's Avatar
Trader Rating: 24 (100%+)
Scroll down to where it shows the parts needed to make mid motorhttp://www.team-durango.com/race-cars/dex210rtr/
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 04-06-2015, 04:43 AM   #16250
bloody hate how the 2.5mm bearing sits so tight into the diff outdrive cup (the one that sits on top of the circlip/thrust)
everytime i remove it to replace/clean the thrust bearing i end up spending 30 mins to bash the bearing out which cost me a new bearing. Gets expensive if you run ceramic
anyone have any tips?
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 04-07-2015, 02:17 PM   #16251
Dino_D's Avatar
Take a dremel felt polishing wheel with some metal polishing compound from home depot and do a quick spin in the cup. It well help remove some scratches which is what is probably causing the binding in the first place so the bearing can slide out free. Don't use the rubber polishing bits (felt only)
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 04-10-2015, 09:55 PM   #16252
i have a dex210 i bought used a while ago that had been collecting dust for a while....
I'M assuming its the rtr because of the one piece composite chassis....
The car is in mid motor.
I just bought the TD cab back body for it (part# TDR402009)...I trimmed it and it doesnt fit. The sides of the body seem to be too narrow where the chassis flares out and reaches its widest point.
Also the marked spots on the body dont exactly align with the body posts.
Any ideas on why this is????
NickTheGreek is offline   Reply With Quote
Old 04-10-2015, 09:57 PM   #16253
your brought the v1 body.
you most likely have the v2 chassis
Old 04-10-2015, 09:58 PM   #16254
rcjunky1's Avatar
the rear cab bod does not fit the composite or v2 chassis, only the standard aluminum v1 chassis
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 04-11-2015, 07:05 AM   #16255
What you have is prob not the rtr chassis. Its the +8mm chassis.
If so, only body that will work is the durango +8 body. And it work for mid or rear motor.
manumanrc is offline   Reply With Quote
Old 04-11-2015, 07:14 AM   #16256
thanks....
Amain has it listed as compatible for the 210 n v2 chassis.
i guess that doesnt do me good in either case being i have the composite chassis.
That was a lil bit of a bummer. i really like that cab back body.
(not to mention i was hoping to throw the electronics in it n take it out for a spin later today)
Now im in a bind....Do i get a different body for 20 bucks or just spend the extra 30 and get the aluminum chassis n side pods??
Will the Silencer fit the compoite chassis??
Old 04-11-2015, 07:27 AM   #16257
I think you might be right.
That would also make sense why the body posts didnt line up with the holes in the body......
Also the body the car came with looks just like the +8 body.....Not only dont i like that body, but the paint job on it is hideous. I cant drive that thing.
I guess im gonna have to buy a different chassis.
Being that i want to use the original cab back body, do i have to buy the aluminum v1 chassis??
Old 04-11-2015, 08:10 AM   #16258
Basically, whatever happens, I'm gonna go broke....
I get the chassis...then I'm gonna want to get the RDRP towers...then the other RDRP/Exotek stuff....brass....titanium etc....fuggedaboudit.
I would've been better off letting it collect dust....I just opened up a can of worms.
If the body had fit, I would've been good to go.....BUT....if I'm gonna have to start buying aluminum chassis', eh...why stop there.
It will fit in nice with the rest of the crew
Old 04-11-2015, 09:17 AM   #16259
Why does he say that like it's a bad thing?
blankenj99 is offline   Reply With Quote
Old 04-11-2015, 09:24 AM   #16260
Admitting you have an addiction is the first step in coping with it!
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16570 Yesterday 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
