Like Tree17Likes
Old 03-31-2015, 10:47 AM   #16231
rcjunky1's Avatar
Nothing really, they're great cars or if the box. If recommend the spring sets though
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 03-31-2015, 11:43 AM   #16232
touringdriver's Avatar
Trader Rating: 15 (100%+)
Anyone know what parts are needed to convert the front axles to associated hex?
Proudly Sponsored by: Mr. Crash Racing, RickyRacer lidz & Ebay..
Rock Chalk Jayhawks
2014 Subway Cup & Dee and Mees On-road Race Schedule:
http://www.rctech.net/forum/kansas-m...l#post11891510
touringdriver is offline   Reply With Quote
Old 03-31-2015, 12:11 PM   #16233
My apologies if anyone mentioned it and I missed it but Exotek has a couple of new things out for the 210. The new rear motor HRC bulkhead conversion is the same mod that Jorn Neumann used at the 2014 Euro Championships. It looks like a nicely machined piece.
http://www.exotekracing.com/dex210-r...ad-conversion/
They've also got a new V2 style rear tower that is 5mm thick.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 03-31-2015, 05:33 PM   #16234
Default Dont hesitate to purchase the dex210v2
BryanAZ .... I've been a team durango owner from day one and have owned every vehicle they make aside from the tc and truggy. I have to say the dex210 is very versatile and has served me well both on indoor carpet and indoor clay surfaces. The only upgrade i've considered a must is aluminum rear hub carriers... I also always keep the infamous itty bitty top shaft bearing on hand as a spare at all times.
Corey McElveen
Hobby Pro PRS1V2 , SB401, PRST1
www.hobbyprousa.com
theycallme_cee is offline   Reply With Quote
Old 03-31-2015, 06:54 PM   #16235
Lone Star's Avatar
Any tricks to getting the gearbox freed up? I have degreased the bearings, removed the shims, spun it up with a drill to break in the little bump on the idler, perfectly torqued the screws for the least amount of pinch. I've set it up as rm3 and 4 to get the most free set of idlers and it still couldn't get anywhere close to any of my b4 trannys. It is good until the other side of the gearbox goes on, almost like it pulls the diff just slight off axis and loads the bearings a wee bit.
DEX210V2, Toxic Tops Shuttle body for DEX210v2, lightened 7075-t6 3mm chassis.
Lone Star is offline   Reply With Quote
Old 03-31-2015, 09:46 PM   #16236
BryanAZ's Avatar
Cool, thanks for the info!
BryanAZ is offline   Reply With Quote
Old 04-01-2015, 03:01 AM   #16237
Trader Rating: 3 (80%+)
Originally Posted by sbv20j View Post
I finally finished building my dex210v2 and fired it up for a test run, but it looks like I am getting to much slip I tightened the slipper clutch up all the way and still could not get the front wheels to raise off the ground when holding the rear wheels what have I done wrong?
Pulled it down tonight I am unable to tighten up the ball diff?
Screw is free to turn but does not tighten up on the t nut ( if that's the correct term)
It will not loosen or tighten
sbv20j is offline   Reply With Quote
Old 04-01-2015, 06:58 AM   #16238
The t nut is probably stripped out.
Old 04-01-2015, 07:24 AM   #16239
theclutch's Avatar
What about the top shaft bearing? And where is this? I don't carry this spare and am wondering if I should. What exactly happens to it?
Thanks in advance.
Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 04-01-2015, 09:41 AM   #16240
rcjunky1's Avatar
It's the little 5x8x3 bearing on the top shaft opposite to the spur side. It's just a tiny thing that takes a ton of abuse. If it fails it can shred the idler gears. I keep an eye on it, if it gets gritty it gets replaced
Team Durango Canada
Old 04-01-2015, 10:20 AM   #16241
theclutch's Avatar
Hmmm...interesting... it's probably a good idea to put a piece of tape over it so that dirt doesn't get in. Thanks for the tip!
Old 04-01-2015, 10:47 AM   #16242
skrichter's Avatar
Send a message via AIM to skrichter
+1.
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 04-01-2015, 11:03 AM   #16243
theclutch's Avatar
I've thought about this for 30+ years of doing RC... I decided that one crash would eliminate any possible advantage that a "super free" drivetrain would provide. I used to remove the shims on the bearings also, but the ultimate maintenance was a horror. The B4 tranny's ARE more free. There is nothing you can do on the DEX outside of shaving down the gears to make them more free. Yes, I've known people who have done that historically and got great results. OR you can just keep running them until they get that way and improve on your driving time while doing so. In a nutshell, IMO, NOTHING beats practice time. Also, the best batteries and best motors will not give you nowhere near the same advantage as practice time...
Old 04-01-2015, 02:39 PM   #16244
rcjunky1's Avatar
The slipper spring makes that impossible
Team Durango Canada
Old 04-01-2015, 03:00 PM   #16245
Dino_D's Avatar
When a hobby shop orders a bunch of bearings, they come in plastic tubes. Some tubes actually fit around the slipper nut and it has a cap that you can remove when you need to adjust the slipper nut.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16561 Today 03:54 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
