Like Tree38Likes
Old 11-07-2011, 01:27 PM   #1606
ABBOTT's Avatar
Other than the c-clip and the ballcups, does the rest of this car seam to have the sturdiness Im use to with my 410? Arms, caster blocks, etc.
SmacTrac / STL Dirtburners / Blaze RC
ABBOTT is offline   Reply With Quote
Old 11-07-2011, 01:33 PM   #1607
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
The only other part that has been giving me issues, is the front hingpin block in the rear of the car. I have broken 2 out of the 3 of mine... iv broken my 3 degree and my 1.5 degree, and am stuck running the last remaining block in the kit, the 0 degree, until spares are available.
So far, the hing-pin block seems like it is the only weak point on the car. There hasn't been much discussion on this issue here on the thread, but I wouldn't think im the only one breaking these. One of them broke with very minor contact with an exposed pipe.
The circlip is a non-issue, and neither are the ball cups if you run the originals. (the ones that come on the 410)
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-07-2011, 01:38 PM   #1608
fullsyzz's Avatar
Trader Rating: 103 (100%+)
Xray T3 circlips should work?
https://www.ssl-stormerhobbies.com/c...s&pn=XRA966080
fullsyzz is offline   Reply With Quote
Old 11-07-2011, 01:43 PM   #1609
onekiwi's Avatar
Says I have to login to keep browsing..
Broke one of my hingpin blocks, ripped the ball out of the hole, happy the LHS had spares tho
onekiwi is offline   Reply With Quote
Old 11-07-2011, 01:49 PM   #1610
fullsyzz's Avatar
I think I fixed the link, try it now. It's part# 966080
Old 11-07-2011, 02:01 PM   #1611
anyone else here break the steering rack? i broke mine a few days ago, i landed pretty flat and turned and thats all she wrote after that. it snapped where the screw goes into. i wonder if they are coming out with an aluminum one.
Team-Powers/Dischargerc.com
derbrylac is offline   Reply With Quote
Old 11-07-2011, 02:03 PM   #1612
ABBOTT's Avatar
So the AL ones I have seen must of been on team cars and not Available yet? I will most likely switch to losi cups since I already made the change on my 410.
Old 11-07-2011, 02:11 PM   #1613
Trader Rating: 66 (100%+)
I read on hear of a couple people and one of the guys at our local track also broke a rear shock tower by flat landing/casing a jump.
If you can't race it or sleep with it, it ain't worth having!
Gwoodrc is offline   Reply With Quote
Old 11-07-2011, 02:13 PM   #1614
Super Moderator
Same exact thing happened to both of the ones I broke. The hingpin ball just tore right through the top/side of the hole
How did the LHS have spares if they don't exist yet?
- RCSpecialties -
Old 11-07-2011, 02:14 PM   #1615
Super Moderator
Any part is POSSIBLE to break... i think the key is to find the ones that break more easily than they should. The majority of this car is built like a tank.
- RCSpecialties -
Old 11-07-2011, 02:17 PM   #1616
onekiwi's Avatar
Think he had a couple of kits hes pulling parts for but I may just have 2 kits on the way as back ups for me, maybe sell one
Old 11-07-2011, 02:34 PM   #1617
Super Moderator
Is there a shock tool for the durango shocks to hold the body tight while screwing on the shock caps? I dont' want to use pliers on the top of the shock body and scratch them!
- RCSpecialties -
Old 11-07-2011, 03:02 PM   #1618
hopsing's Avatar
Trader Rating: 13 (93%+)
With the o-ring on there I havent had the need to do it tighter than hand tight. I have no leaks from the cap at all.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 11-07-2011, 03:05 PM   #1619
Matt Howard's Avatar
+1, hand tight is fine, no leaks here either
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-07-2011, 03:06 PM   #1620
hopsing's Avatar
Patrick at SDRC broke his rack.... he glued it back together and traced it out on a piece of aluminum and cut it out to make his own.
Steve Butts
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
