Like Tree24Likes
Old 11-07-2011, 09:01 AM   #1591
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Gwoodrc View Post
I was wandering if anyone has tried the rm3 to rm4 back to back yet to really get a good compairison on the track? I'm sure Cpt. would have if he hadn't spent 5 of the 6 hrs working on the diff (but atleast you have practice pulling the tranny now ), maybe Randy or someone else has had a chance . I am leaning toward rm3 just because every sucsesfull Pro driver with the car trough testing have been running rm3, even in europe on the bigger tracks, and if the rm4 was so any better than you would think that Jorn or some of the other drivers would have been running it .
They are also running on turf, no? Generally you will want to stick to RM3 if you have plenty of forward traction, and tire spin isn't an issue. (which is the case on turf/carpet). The lower the traction levels, the more you lean towards a rear-motor setup... first in the 3 gear, then last in the 4 gear.
If you can't get forward traction to your drive tires, you wont go anywhere, right? So it's just an option for fine tuning whether you have a front tire traction on-throttle bias , or a rear tire traction on-throttle bias.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-07-2011, 09:25 AM   #1592
madweazl's Avatar
Originally Posted by teeforb View Post
i haven't been following this thread much lately. been to busy racy the 210... i am digging this buggy! So far, there are about 4 of us at the track. i tq and won sportsman buggy today. almost lap 2nd place. guys are complaining i should be running with the experts... lol... i would, but then i'll be loosing... the next track change i will go to expert... but this buggy is hooked up! i am running rm3...
We need a few more entries on a consistant basis.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 11-07-2011, 09:52 AM   #1593
murky123's Avatar
any news from durango on the next batch ?
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 11-07-2011, 10:10 AM   #1594
Super Moderator
So I think I figured out what is wrong with my diff. I first want to appologize for getting all huffy-puffy about the car here on the forums... But after so much wrench time and so little run time on my only race day of the week, I was boiling over with frustration.
The issue with my diff is certainly a bad circlip. What was happening was, the circlip was popping out while running the car on the track, screwing up the diff. But then when pulling the diff apart to examine the diff for issues, I found the cirlip still installed... so that didn't LOOK like the problem. The clip was popping out a bit on the track, and it would then re-seat itself when I was taking the diff apart, fooling me into thinking that the clip wasn't the issue. Heck, it looked like it was in just fine, and in the right way.. but upon careful close examination and tinkering, i could get the clip to pop out with a bit of pressure from the other side.
So, I have a hand full of replacement circlips coming this week, and i'm 100% positive a new clip will fix all my issues.
- RCSpecialties -
Old 11-07-2011, 10:22 AM   #1595
hopsing's Avatar
Trader Rating: 13 (93%+)
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 11-07-2011, 11:12 AM   #1596
Where did you purchase the replacement circlips? I am having the same issue with my diff but am having trouble finding replacements. Every place i find them there is a minimum $25 order.
egilliland23 is offline   Reply With Quote
Old 11-07-2011, 11:14 AM   #1597
Super Moderator
mcmaster carr has 50 for $8... or fastenal $25 for the larger order. I myself got 20 on ebay for $8. (oops)
http://www.mcmaster.com/#retaining-rings/=eu0fdp - Scroll down a bit and you will see Metric Internal Retaining Rings.
- RCSpecialties -
Old 11-07-2011, 11:18 AM   #1598
Thanks! $8 is better than $25. i too was frustrated with the diff this past weekend and did not come across the circlip problem until i got home and played with the diff on the bench.
Old 11-07-2011, 11:26 AM   #1599
Super Moderator
For dependability, you really don't want to compress any given circlip more than once. Which means you burn 1 clip for every rebuild. Well I take my diff apart every other week, which means about 20-25 builds a year. ... that's going to require (for me anyway) 20-25 clips a year.
If you have other guys running this car at your track, just get a $25 order and maybe split it up amongst a few guys. I know a bunch of people that only clean or rebuild their diff a few times a year... so YMMV on the number of clips needed I myself would rather order a LOt.. and never have to worry about buying more later.
- RCSpecialties -
Old 11-07-2011, 11:31 AM   #1600
Glowster21's Avatar
Trader Rating: 116 (100%+)
First off, props to you for honestly apologizing about getting "huffy" about the diff issue. It happens way to often that people jump on a forum and get that keyboard courage and just bash away, find out it was them who was the problem, then just keep bashing to try to cover up their boo boo. It takes more courage to do what you did and apologize so, not that I'm anybody or anything special, but hats off to you sir for stepping up to the plate. Now the real reason I'm chiming in is that if you're in a pinch and don't want to miss a race day while waiting for your clips, the Schumacher or Corally clips that come with their diff screws fit the 210 like a glove. Again bro, hats off to you...
Glowster21 is offline   Reply With Quote
Old 11-07-2011, 11:31 AM   #1601
I just went ahead and got a 50 pack. I did compress the clip more than once when i first built the diff. I suspected that is what caused it to fail and it seems like you just confirmed that idea.
Old 11-07-2011, 11:34 AM   #1602
onekiwi's Avatar
Which one is it?
13 13.6 1.1 14.1 1 50 98455A113 6.67 5 98394A425 7.39
14 14.6 1.1 15.1 1 50 98455A114 7.83 5 98394A427 5.18
15 15.7 1.1 16.2 1 50 98455A115 7.83 5 98394A429 7.91
16 16.8 1.1 17.3 1 50 98455A116 8.22 5 98394A431 5.61
onekiwi is offline   Reply With Quote
Old 11-07-2011, 11:37 AM   #1603
Super Moderator
But not just that.. even MORE important is to make sure that the flat side/face of the clip is the side holding the clip in, and the rounder side is sitting up against the thrust assembly.
- RCSpecialties -
Old 11-07-2011, 11:38 AM   #1604
Super Moderator
Originally Posted by onekiwi View Post
Which one is it?
None of those... I think its the first on the list? a "For Bore" of "8", 8.7mm diameter, 0.8mm thick. that would be "98455A108"
- RCSpecialties -
Old 11-07-2011, 11:41 AM   #1605
I ordered 98455A108...it is the first one on the list. I did have the clip in the correct way i think i just compressed it too much when i put it in.
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
