Like Tree43Likes
Old 01-29-2015, 10:42 AM   #15871
Traction is increasing at our new track and the fine, slippery dust layer is going away. Clay compounds are being run now and the tires are starting to squeal in corners. Grip shouldn't be a problem anymore so my MM3 setup will probably be fine after all. I'd still prefer loose, loamy dirt.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 01-29-2015, 10:45 AM   #15872
ohiostatechamp's Avatar
Trader Rating: 48 (100%+)
A well built 4 gear transmission will spin just as free as a 3 gear transmission. The only reason a 3 gear transmission should be used is as a tuning option. This option has been available on the DEX210 since the day it was released. There are very few three gear transmission set ups. I think this is for a good reason. XFactory pioneered the 4 gear transmission. It started with Brian Kinwald looking for more rear traction and a more natural feel with his car.
P.S. It takes me 2 days to build a transmission but the results are amazing.
Team Durango, Viper R/C Solutions, Trakpower,
Maxy fuel, Panther Tires, DE Racing, B-Fast
ohiostatechamp is offline   Reply With Quote
Old 01-29-2015, 12:09 PM   #15873
I don't think there's anything natural feeling about a 4 gear setup. In fact I find the opposite true. 3 gear is so much more neutral. 4 gear is a compromise solution to a problem that wasn't properly identified at the time. That compromise has become the standard.
Old 01-29-2015, 12:45 PM   #15874
What was the miss identify problem? I was told that it had to do with weight shift and inertia from the motor. Is this not correct?
Old 01-29-2015, 12:55 PM   #15875
tc5 man's Avatar
Fred is right the 4 gear mid motor has a lot of weight transfer it becomes to twitchy and inconstant at times I felt. The 3 gear mid motor for sure feels more natural all around .
I'm more used to rear motor on 2wd but the 3 gear mid motor felt similar but better and constant .
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 01-31-2015, 03:52 PM   #15876
LoudOne's Avatar
Trader Rating: 31 (100%+)
Hey all, I've always struggled w/ the whole spur/pinion thing. Normally I run an 18 or 19 tooth pinion w/ the stock spur that comes w/ most kits which are around 87 tooth. What are your current set-ups? Thanks!
LoudOne is offline   Reply With Quote
Old 02-03-2015, 08:00 AM   #15877
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Smile
What kind of motor are you running? 18 or 19 seems a little small. I don't usually go smaller than 20 or 21, and I run a 7.5T and sometimes a 6.5T. Are you running a 17T?
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 02-03-2015, 08:02 AM   #15878
13Maschine's Avatar
Does anyone know for sure if this would be the right block to do HRC on the Type B chassis?
http://www.exotekracing.com/dex-desc...nger-type-b-5/
I already have the exotek quick change so I figured I'd keep the color scheme and save a little over the Durango HRC block.
Old 02-03-2015, 08:04 AM   #15879
That block gives you an extra .5 degree of rear toe. This block doesn't. Both are HRC for a type B chassis. http://www.exotekracing.com/dex-desc...hanger-type-b/
Old 02-03-2015, 08:06 AM   #15880
rcjunky1's Avatar
That is if you wanted the extra toe
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 02-03-2015, 11:35 AM   #15881
Dino_D's Avatar
Mid
3 gear is more neutral in Mid Motor.
4 gear has more weight transfer and std in most mid motor cars.
Rear
3 gear has more weight transfer in rear motor which is the standard in most RM cars.
4 gear is more neutral in Rear Motor. If you don't flip the motor to the proper side in RM4 and have to reverse the motor direction via ESC, its not the same thing - the inertia is different.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 02-03-2015, 12:11 PM   #15882
Originally Posted by Dino_D View Post
Mid
Rear
Dino, how many times are you going to keep saying that? You are 175,000% WRONG!
4 gear always behaves like 4 gear in MM or RM. 3 gear always behaves like 3 gear in MM or RM. 4 gear ALWAYS transfers more weight. 3 gear ALWAYs feels more neutral. RM or MM is 100% irrelevant!!!
How many more times do I have to repeat this???????????
Old 02-03-2015, 01:01 PM   #15883
tc5 man's Avatar
I tested out the Mid motor 3 gear tell you what i like that its much easier to drive than the 4 gear mid motor . Not nearly all the weight transfer compared to the 4 gear mid motor and less twichy.
Steering wasn't bad .
However when the grip is lower it needs some small tuning.
Im running the 3 gear mid motor with the mod motor.
Old 02-03-2015, 01:27 PM   #15884
Yup. That's solely from a lack of weight on the rear wheels.
Old 02-03-2015, 01:36 PM   #15885
tc5 man's Avatar
That is why though i moved the battery toward the rear end so it wasn't terrible.
St Ives RC Club B4Bandit Australian Racing 16576 Yesterday 07:25 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
