Like Tree43Likes
Old 12-13-2014, 10:20 PM   #15541
tc5 man's Avatar
Originally Posted by 303slowdown View Post
You shouldn't have to. I ran yokomo hexes on mine and they had that lip , worked fine for me. You will have to reshim your axels to have correct play.
Ok did you use the same axle shims that were inside the Rear hubs onto the axles ?
Like take one off or so ?
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 12-13-2014, 10:48 PM   #15542
tc5 man's Avatar
Originally Posted by Dino_D View Post
Let me ask you a trick question.
Shock collars on the bottom. Which ones you have on front and rear. You know they are not the same. THere are ones marked with "0" the other says "2" if you put the wrong ones on, your collars will be very off.
Ok the Rear shocks have the number (2) shock collars on the bottom and the Front one of them has a (1) and the other (0) .
Old 12-14-2014, 06:13 AM   #15543
asalas's Avatar
Send a message via Skype™ to asalas
Default Spur - pinion gears ratio
Hi guys,
Can somebody help me understanding the Dex210 v2 gear chart? It is on P.45 of the manual.
I'm still learning about rc cars and my Dex210 and I've been told that I should change my pinion and spur gears to a 69t pinion and a32t spur (I think, I didn't write down what this guy at my rc track recommended), The set comes with a 81t pinion gear and a 29 spur gear.
I would change them asap but I have no idea about what the meaning of all the numbers I see in the gear chat is. What is the meaning of the 2.6 internal ratio? 81t and 29t apparently give me 7.26, but what does 7.26 mean? How do you calculate which pinion correspond to which spur? I saw this guy using his calculator to tell me I should go 69t with 32t? But I didn't get why.
I hope somebody can help me.
Thanks.
asalas is offline   Reply With Quote
Old 12-14-2014, 08:34 AM   #15544
theclutch's Avatar
Originally Posted by tobamiester View Post
Wierd. Can you post a picture pls ?
Double weird... I've never had this happen and I have about 80 actual racing/practice hours into my DEX.
XRAY XB2 2018, XRAY XB4 2017, Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 12-14-2014, 08:50 AM   #15545
tobamiester's Avatar
Trader Rating: 281 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Originally Posted by tc5 man View Post
I was searching around and found out these will work there for the B4.1 rear end. Thinking i just need to take the lip off them or completely ?
Pro-Line Aluminum 12mm Rear Clamping Hex Wheel Adapter Set (Blue) (2)
[PRO6077-00]
Running B5 Alum Clamping hexes in Rear. No issues.
tobamiester is offline   Reply With Quote
Old 12-14-2014, 10:54 AM   #15546
tc5 man's Avatar
Do the stock Dex210 axle pins fit though them hexs or do you need the B5 axle pins ?
Old 12-14-2014, 03:47 PM   #15547
If I recall, I used the AE pins that came with the clamping hexes
Old 12-14-2014, 04:00 PM   #15548
Jeepy2013's Avatar
Trader Rating: 79 (100%+)
Does using those hexes along with AE wheels retain the factory width of the car?
Jeepy2013 is offline   Reply With Quote
Old 12-14-2014, 04:51 PM   #15549
tc5 man's Avatar
That's a good question . If more than one guy does it i guess it remains the same wheelbase guess its fine.
Old 12-14-2014, 05:56 PM   #15550
As I recall when I did the measurements the net change is -.5mm per side.
Wanderer77 is offline   Reply With Quote
Old 12-14-2014, 06:13 PM   #15551
tc5 man's Avatar
So it sounds like with the 12mm your narrowing the track witch that might be a bad or good thing .
Old 12-14-2014, 06:29 PM   #15552
If you want the same track width or even a little wider just use some track width spacers. Avid makes some really sweet cf ones in .5mm and 1mm widths. I played around with some different widths and actually came to like the -.5mm per side width. I do race on a super tight indoor track though, so you may like something different.
Old 12-14-2014, 06:30 PM   #15553
ohiostatechamp's Avatar
Trader Rating: 48 (100%+)
Ran my mid motor today for round 4 of the South Florida Winter Series. I finished 3rd in stock buggy. Class had 27 entries. I was 1.2 seconds from first. Car ran awesome.
Team Durango, Viper R/C Solutions, Trakpower,
Maxy fuel, Panther Tires, DE Racing, B-Fast
ohiostatechamp is offline   Reply With Quote
Old 12-14-2014, 07:14 PM   #15554
Yup, Doesn't change it much.
Here is a pic of my rear w/ B5 Hexes.
Old 12-14-2014, 07:47 PM   #15555
ekt
ekt's Avatar
Originally Posted by asalas View Post
Hi guys,
Thanks.
An internal ratio of 2.6 means the layshaft gear turns 2.6 times to turn the diff once.
7.26 refers to the final drive ratio, how many times the motor spins to get the wheels to spin once.
To work out your FDR use this formula. (Spur Pinion) x Internal Drive Ratio = Final Drive Ratio.
I'm guessing you are running 17.5 buggy from what gearing you were recommended.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16575 Today 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
