Like Tree23Likes
Old 12-09-2014, 10:47 PM   #15526
Dino_D's Avatar
Originally Posted by tc5 man View Post
There TD springs thinking about it i could of treaded it all the way up and got 20mm i was in a hurry though my race was coming up . The push i was talking when i tried a Slick on the Rear and a Ion in the Front (Clay) . With Slicks all around there was hardly any push inless i over drove , last weekend the track was tacky and stayed moist all day.
Im using 32w (F) and 30w (R) with the stock springs and tried the stiffer spring with the 30w oil in the rear shocks i like the stiffer spring a little more haven't tried the stiffer spring on the Front yet. I do have my ESC in the back of the Shorty pack 2nd time driving with it i like it you can drive it a little harder with more rotation .
My droop i haven't done the measurement but the Front and Rear the screws are just touching a little on the chassis not full.
Let me ask you a trick question.
Shock collars on the bottom. Which ones you have on front and rear. You know they are not the same. THere are ones marked with "0" the other says "2" if you put the wrong ones on, your collars will be very off.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 12-09-2014, 11:40 PM   #15527
tc5 man's Avatar
Il look at it and see.
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 12-13-2014, 08:46 AM   #15528
Hi,
I just assembled the v2 and had it race on a local track yesterday. I did not managed to finish both of my heats due to my rear shock shaft keeps popping out of its ball end. There were 3 of us running the v2 and all of us had the same problem.
I resorted to apply some superglue to the threads but to no avail.
Is it a common problem? And is there any solution to it?
darkdays is offline   Reply With Quote
Old 12-13-2014, 09:09 AM   #15529
tobamiester's Avatar
Trader Rating: 274 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Originally Posted by darkdays View Post
Hi,
Wierd. Can you post a picture pls ?
tobamiester is offline   Reply With Quote
Old 12-13-2014, 03:04 PM   #15530
ekt
ekt's Avatar
Hi,
I went back to the old shock ends and that fixed my issues, #TD330293.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 12-13-2014, 03:22 PM   #15531
tc5 man's Avatar
Cant say i ever had that issue with the V2 version.
Old 12-13-2014, 04:27 PM   #15532
tc5 man's Avatar
Does anybody know what would work to use 12mm hexs on the Rear end ? Without a ton of mods at worst shaving down or off the lips .
I can get a Evo conversion kit for the 14mm so i can use wider buggy tires and Typos, Chainlink tires . But if there is a hex that would work i don't need to .
Old 12-13-2014, 06:51 PM   #15533
tc5 man's Avatar
I was searching around and found out these will work there for the B4.1 rear end. Thinking i just need to take the lip off them or completely ?
Pro-Line Aluminum 12mm Rear Clamping Hex Wheel Adapter Set (Blue) (2)
[PRO6077-00]
Old 12-13-2014, 07:10 PM   #15534
303slowdown's Avatar
Trader Rating: 21 (100%+)
Yes those will work
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 12-13-2014, 07:12 PM   #15535
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
The Avid, JC, and Pro Line 12mm hexes all work pretty well.
Has anyone bent their alum chassis ? I've bent the V1 and the V2, minor but when disassembled you can see a little bit of a tweak. I'll post some pics as soon as I can disassemble it.
I also picked up the Exotek graphite chassis as a replacement since graphite doesn't bend and because I'd like to see how the car handles with the graphite. Perhaps a little more traction with the flex differences vs alum. Has anyone else tried it?
Thanks ahead of time!
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 12-13-2014, 07:12 PM   #15536
tc5 man's Avatar
Originally Posted by 303slowdown View Post
Yes those will work
Cool thanks. Now would i need to dremel off the lip on them or anything ?
Old 12-13-2014, 07:16 PM   #15537
Carbon chassis don't bend but they will tweek, I've had a few touring car chassis do it. Not quite as noticeable as an aluminum one though.
Ryan Borgheiinck
Old 12-13-2014, 07:21 PM   #15538
You shouldn't have to. I ran yokomo hexes on mine and they had that lip , worked fine for me. You will have to reshim your axels to have correct play.
Ryan Borgheiinck
Old 12-13-2014, 08:21 PM   #15539
13Maschine's Avatar
Does that mean you have bent alum and tweaked graphite both?
Old 12-13-2014, 08:24 PM   #15540
It does lol. I'm kind of hard on stuff
Ryan Borgheiinck
St Ives RC Club B4Bandit Australian Racing 16563 Yesterday 04:32 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
