Like Tree17Likes
Old 11-20-2014, 09:06 AM   #15436
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
I've used the avid triad slipper in my MM4 DEX210v2 and it's much more consistent and I did notice better acceleration. I was testing with a 6.5T mod motor though, so it's hard to tell if that extra at the bottom end of the power curve was from better slipper action or lower rotating mass. A little of both I would imagine. I'll be testing with a stock motor soon.
If you had this upgrade you could use the Schelle locker when you want to lock it up too. Get some red pads and you will have many tuning options.
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 11-20-2014, 02:31 PM   #15437
Dino_D's Avatar
Originally Posted by Tdub77 View Post
Thanks Fred, so will the shorter chassis, whether it's the aluminum or dimec work on the v2 car without replacing parts?
Tim
You have to get the Type B dimec (med flex) or Type B dimec20 chassis (hard) which is a direct bolt onto the v2 car. I use the Dimec outdoors on low to med grip tracks, and Dimec20 on very hot days or high grip tracks. I prefer the flex of the plastic when running outdoors. Its more forgiving and easier to drive.
I only use the aluminum chassis in mid motor high grip situations.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 11-20-2014, 02:35 PM   #15438
Dino_D's Avatar
Originally Posted by LoudOne View Post
Thanks everyone for all the guidance/suggestions for the slipper clutch! What do you think about the following solution?
http://www.avidrc.com/product/5/acce...cessories.html
Yes that is what I used on my car. Make sure you order the Red pads. I normally use 1 red pad in the center. As grip goes up, you can use 2 red pads. But if you have crazy grip, then get the locker from Schelle as well. Or you can try the Exotek option.
Old 11-20-2014, 02:53 PM   #15439
Big Midget's Avatar
Trader Rating: 98 (100%+)
sorry to interrupt but why would you want to use a locker? I'm assming that locks your slipper and might cause damage?
I just started racing a dex210 and I have the avid/schelle slipper.
Dee & Mee Hobbies
Fastlane Raceway-wwwfastlanehobbies.com
Topeka On-Road Racing-Jake's R/C Pro-Am Topeka,Ks
www.ZigPhoto.com,RickyRacer Lidz,Absolute Tattoo,Fuzzy Dice Decals
Big Midget is offline   Reply With Quote
Old 11-20-2014, 03:01 PM   #15440
Dino_D's Avatar
That is correct, not having a slipper can cause damage to your idler gears.
That's why I would recommend using at least 2 red avid slipper pads in stock 17.5 or 21.5. But in some cases, some people need to almost lock or lock their slipper on high traction surfaces in order to gain as much acceleration as possible - hence locking the slipper. The high turn stock motor can't generate a as much power anyways. Its landing on power that can wreck the idler gears in stock racing with a locked spur, or jamming the throttle when you are stuck on a pipe
Old 11-20-2014, 03:08 PM   #15441
Big Midget's Avatar
Thanks for the reply Dino_D. Sounds like I need some red pads.
Dee & Mee Hobbies
Old 11-21-2014, 04:08 AM   #15442
slashdad's Avatar
Trader Rating: 33 (100%+)
How do I get more in power steering on the long sweeper in my med grip dirt track?
Been running a full pack, considering a change to shorty. 32.5/30 wt oils, JC Rips and 3d's rear, mod MM4 setup. Any suggestions on droop changes front and rear and anti squat for a loose at times dirt track with one large jump and a couple of smaller jumps and table tops. Your suggestions would be welcomed.
B5M, T5M, B44.2, B4.2, DEX210v2, SC10B, Xray T3 2012.
Savox : Spektrum : Proline : JConcepts : Turnigy : Trackstar Gen II's
Knox OFF Road RCC member, waiting for toddler to grow up...
Please explain roll centres to me one more time...
slashdad is offline   Reply With Quote
Old 11-21-2014, 05:26 AM   #15443
Thanks Dino
Tdub77 is offline   Reply With Quote
Old 11-21-2014, 07:42 AM   #15444
Dino_D's Avatar
I would leave the antisqaut at 1.5. That gives you a good balance of side bite and forward traction. If you go 3 antisqaut you will loose bite in corners but have better forward traction, going 0 will give more side traction in corners at the expense of forward traction.
The front droop is the biggest setting change that I do to tune my car to the track. I don't really touch any other setting but adjust the front droop first. Reduce droop, turning the screws in (front arms higher up) will give you a more direct steering feel. It will increase more on power steering. If you find the car having too much steering out of corners, then back off the droop screws to give more droop/suspension travel.
I normally run max droop in the rear, which gives you a lot of off power steering. If you find it too much, then you can always reduce 1-2mm in the rear.
Old 11-21-2014, 05:19 PM   #15445
Devin's Avatar
Can someone confirm this is the V2 shock tower set?
http://www.amain.com/team-durango-sh...er-set/p213151
If it isn't, can I get a link to it please?
Regards,
Devin is offline   Reply With Quote
Old 11-21-2014, 05:25 PM   #15446
ekt
ekt's Avatar
Regards,
That's the v1 towers, here's a link to the v2 http://www.amain.com/team-durango-sh...type-b/p298932
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 11-22-2014, 12:09 AM   #15447
Dino_D's Avatar
Yeah if you run the stock white avid pads. The white pads will feel like you don't have power cause its slipping too much. That's why you need 1 or 2 reds in there to give you the punch out of corners in stock. Even run 3 reds if the grip is super high and you don't have a locker .
Old 11-22-2014, 10:05 AM   #15448
cryofix's Avatar
so I finally got my 210v2 running well last night at critters, but I could not get the car to turn. I drove my sons AE4.2 and that had tons and tons of steering but my car I had to wait for it to turn.
I am running box stock v2, with super soft IONs, mostly the same exact tire as everyone else including my sons car.
Any suggestion on how to dial some steering into this?
Futaba :: DEX8 DEX8T DEX410V4 DESTV1 DEX210V2 :: Hobbywing
Wednesday: http://leisurehoursraceway/com Leisure Hours Raceway Joliet IL
Friday: http://www.critterhobbies.com Crispy Critters
Sunday: http://tandlracing.com Trains and Lanes Easton PA
cryofix is offline   Reply With Quote
Old 11-22-2014, 03:18 PM   #15449
tobamiester's Avatar
Trader Rating: 274 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
I took out some Toe in the rear. That helped alot. I also put the shocks on the rear of the tower and that made a ton of difference for me
tobamiester is offline   Reply With Quote
Old 11-22-2014, 05:48 PM   #15450
tc5 man's Avatar
How did you mount the Rear shocks behind the tower without the wing getting in the way ?
Cyofix : Yea in the beginning i dint have enough steering to i messed with the wheel spacers on the rear hubs to make the wheelbase shorter and went to the Rear hole on the steering rack for sure more steering . T
he +8 chassis takes away steering but much easyier to drive with !
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
St Ives RC Club B4Bandit Australian Racing 16561 Today 03:54 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
