Like Tree23Likes
Old 11-19-2014, 10:23 AM   #15421
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
On my stock slipper pads I use to use emery cloth and rough them up a little so they would bite better. This use to work well for me.
That is one very nice looking Dingo.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 11-19-2014, 11:02 AM   #15422
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
anyone use garolite discs?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 11-19-2014, 12:21 PM   #15423
fq06's Avatar
Yep, snug fit but they do fit. Same awesomeness that we saw with them in the sc10 4x.
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 11-19-2014, 02:30 PM   #15424
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
@DINO_D: "Run the Avid Locked slipper mod" What's the part number on this? I've seen the exotek but I can't seem to find info on this version.
Since stock is SUPER popular at my local track I'm building a stock racer. Super light and perhaps the Exotek slipper eliminator. It is generally a medium to high bite track. Have you also tried the Avid slipper? Better for stock? Supposed to be lighter. I'm currently using the lightened plates from Durango and I use the associated pads with the larger surface area.
Here's the exotek for anyone else thinking about itů
http://www.exotekracing.com/dex210-direct-spur-mount/
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 11-19-2014, 03:17 PM   #15425
Pittster's Avatar
Originally Posted by Tdub77 View Post
So I here from time to time that a Dex210 is a bit heavy for stock so will the plastic short chasis work on the v2
I run my Dex210v2 with a Dimec20 Type B chassis with ESC mounted at the front in MM4 with Shorty pack and a fan my weight is 1590g.
My car has plenty of pace in Stock even with the weight and a 12.3mm rotor if I really wanted to make it the ultimate Stock racer i would do the following
3200ma Shorty battery (50g weight loss)
Shorty servo (25g weight loss)
Ti Screws and turn bukles (20g Weight loss)
Mount ESC in side pod to reduce wiring (10g Weight loss)
Ditch Fan (13g weight loss)
12.5mm torque rotor
Then reduce rotational mass
Exotek Direct spur mount
Alloy top shaft
Light weight outdrives or Gear Diff with plastic internals
MM3 if the negatives of less squat are OK
That would get the car down to a 1500g level.
I haven't felt the need to go that extreme yet becasue in my opinion until I can do 5 min races with 0 mistakes as long as the buggy is similar speed its all driver
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 11-19-2014, 03:31 PM   #15426
GasGod's Avatar
+1 I have never felt that the 210 was not a good 17.5 car.
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 11-19-2014, 06:58 PM   #15427
Thanks guys, that was my thought also about it being a competitor but I thought Id ask...would the shorter chassis work better for off road carpet?
Tim
Tdub77 is offline   Reply With Quote
Old 11-19-2014, 07:57 PM   #15428
303slowdown's Avatar
Trader Rating: 21 (100%+)
Tim
All depends , if your track has a lot of sharp turns the short chassis would be better but if the track has lots of sweeping turns than the +8 or a +11 would be better IMO.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 11-19-2014, 08:20 PM   #15429
I had a +8 chassis for a while but now I'm back to the shorter one. The only time I feel that the longer chassis is necessary is when the track is large and basically long high speed straights connected by a few corners where speed is really the only thing that matters. If the track is actually somewhat creative and not built to appease the no talent rednecks, I like the standard better. A limo really doesn't have an advantage in many places.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 11-19-2014, 10:40 PM   #15430
Dino_D's Avatar
The exotek works good as well. But if you are talking about the Avid. It's called Schelle racing now.
http://www.schelleracing.com/Schelle...-Plate-SCH1315
I think the Avid is better for Mod racing than stock using the stock pads. It is a smoother slipper than the stock durango and doesn't glaze. I normally opt to use the AE pads, they are more consistent and last longer.
If you use avid in stock, yes it is lighter but you need the more aggressive red pads or just lock it using the locker. But I only use avid on the mid motor. Its soft gear cover doesn't last in rear motor.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 11-19-2014, 10:46 PM   #15431
tc5 man's Avatar
Once i figure out the issue with using full throw on the steering without the steering turnbuckles hitting the shock spring.
I may try out the shorter chassis since the indoor tracks i go to are tight not really big tracks just a small and medium size no sweeping turns really so i cant see a real need for the +8 chassis.
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
tc5 man is online now   Reply With Quote
Old 11-20-2014, 01:30 AM   #15432
Doughty's Avatar
To those that raised their opinion to say that the DEX210 is not a good stock racing car, I'm interested to know why you believe this is the case.
To those that have offered their suggestions and feedback to these guys, Many Thanks.
Chris Doughty - Team Durango - LRP - BETA Tires - Nibbo Design
Doughty is offline   Reply With Quote
Old 11-20-2014, 01:42 AM   #15433
ekt
ekt's Avatar
The DIMEC and DIMEC20 chassis types are the same length and shape as the v2 chassis with sidepods.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 11-20-2014, 03:00 AM   #15434
LoudOne's Avatar
Trader Rating: 31 (100%+)
Thanks everyone for all the guidance/suggestions for the slipper clutch! What do you think about the following solution?
http://www.avidrc.com/product/5/acce...cessories.html
LoudOne is offline   Reply With Quote
Old 11-20-2014, 03:07 AM   #15435
Thanks Fred, so will the shorter chassis, whether it's the aluminum or dimec work on the v2 car without replacing parts?
Tim
St Ives RC Club B4Bandit Australian Racing 16564 Yesterday 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
jcr
