Like Tree23Likes
Old 11-11-2014, 01:13 AM   #15376
Originally Posted by tc5 man View Post
I took a look at the manuel for the Dex210 V1 and it showed how to do the 3 gear mid gear and it looks like the spur gear and motor are at the same position as the 4 gear mid gear Spur gear on the driver side/motor endbell on the right side ?
Hello tc5 man,
Have a look at the Team Tech Tips, there you can see how the positions are from the motor and the spur gear.
http://www.team-durango.com/in-the-p...rticle_id=4472
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 11-11-2014, 09:08 AM   #15377
tc5 man's Avatar
Originally Posted by micholix View Post
Hello tc5 man,
Thanks. I see now the motor plate is on the right side with the motor endbell pointing to the left with the 3 gear mid gear motor right ?
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
tc5 man is online now   Reply With Quote
Old 11-12-2014, 12:59 AM   #15378
Yes, that's right!
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 11-12-2014, 05:36 PM   #15379
RC10Nick's Avatar
Now that I finally finished building my CNC router, I can get to the real fun part, making RC parts! This is my prototype chassis. If all goes well, I've got a sheet of carbon fiber sitting around to make the final version.
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 11-12-2014, 09:26 PM   #15380
Hello RC10Nick,
That looks nice! I'm looking forward, to see it out of cf aswell...
How do you plug the front piece on that chassis?
PS.: man, i need one of those cnc routers, too!
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 11-13-2014, 03:25 AM   #15381
RC10Nick's Avatar
The nose will bolt on the same way as my old hand made chassis. It's the same way x factory does it.
JT RC Products
Old 11-13-2014, 06:14 AM   #15382
Looks good!
Does just the plastic servo mount hold them together, or do you use any other stiffener aswell?
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 11-13-2014, 09:46 AM   #15383
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Looking good Nick. Interested to see how it works for you at Bumps with your new chassis setup.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 11-13-2014, 04:58 PM   #15384
RC10Nick's Avatar
If all it does is work as well as my current hand made chassis but just look better, I'll be happy!
I'm hoping it will work better for the track. I designed it to be the short v1 chassis length. I have a hunch most of us don't really need a +8 chassis indoors.
And now for an update!
top deck done! I discovered my transmission cutout is off by 1mm. No big deal. A little dremel work will fix it right up. It's a prototype for a reason!
JT RC Products
Old 11-13-2014, 07:15 PM   #15385
Lone Star's Avatar
Default spur gears
What's everyone doing for smaller spur gears? Triad, schuey, cnc durango, ream out ae's. I have reamed out an ae75 for a quick fix. I have designed a simple trackside jig to ream ae spurs.
If a simple reaming jig was available to mod ae spurs, how many would want one?
DEX210V2, Toxic Tops Shuttle body for DEX210v2, lightened 7075-t6 3mm chassis.
Lone Star is offline   Reply With Quote
Old 11-13-2014, 08:51 PM   #15386
fq06's Avatar
I'd be in for one.
Running Durango machined spur and they are thick. Would like to change to AE spurs.
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 11-13-2014, 11:35 PM   #15387
tc5 man's Avatar
I haven't had issues with the stock spur gears actually . But does the B5 slipper pads work on the Durango slipper ?
Do you guys use the Purple shock O-rings in the shocks that come with this buggy ? Im finding that are stiff and get that slicktion if that's what you call it like a tight feeling kind of and when i mount them on the buggy there not that smooth its like a scratchy feel when there compressed .
Old 11-14-2014, 03:51 AM   #15388
Lone Star's Avatar
B4 pads work fine. Im pretty sure that the b5 pads are the same.
Old 11-14-2014, 06:03 AM   #15389
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
did tresrey stop making that layshaft they had?
Have an avid setup here with lots of spurs if anyone is interested including stuff for stock and mod sizes. Just don't really run stock out here enough to make it work keeping.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 11-14-2014, 10:13 AM   #15390
Dino_D's Avatar
The purple ones should be smoother than the orange ones. First, did you put some green slime or silicon as you installed the o rings into the shock cartridge?
Also there is a plastic insert that goes inside the bottom of the shock cap. Make sure you have that insert the right way otherwise you will squeeze the o ring more than necessary. The lip of the insert faces the bottom of the shock cap.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
