Like Tree26Likes
Old 11-09-2014, 12:31 PM   #15346
tc5 man's Avatar
Originally Posted by 13Maschine View Post
Were you coming from a rear motor car previously? Sorry if you mentioned this before...
No rear motor ran on this buggy. The Clay was high grip/tacky most guys ran mid motor.
I learned that Slick tires are inconstant when the clay is dry .
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 11-09-2014, 04:37 PM   #15347
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
yes, I've learned this about slicks as well. They can be amazing and also terrible. Not often in between. Ghost pins are sometimes better if you are using a real slick like the panther. Hard to say not knowing the track but perhaps electrons or dirt webs are the ticket for you. The high grip indoor clay seems fairly similar around all the west coast tracks I've been too. We have two here that are very similar to this it seems and i've found dirt webs, typos and barcodes to all be good choices on this type of track. Barcodes more if it's somewhat drier and perhaps dusty on top.
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 11-09-2014, 05:10 PM   #15348
tc5 man's Avatar
Yea they where good in some corners of the track when it was dry even with traction compound and some other corners all the sudden i spin out going out of a corner not real hard on the throttle. I need to get Shorty lipos also i seen some 4000mah that look good.
I do have some new Ion (Clay) Front and Rear tires il run in the parking lot or use traction compound to get wear although they are almost like Slicks very little tread. When the Clay was dry i dint see any dust if there was it was very little but it felt colder on the track later in the day.
One thing i did notice is i needed a little more turn in it was lacking into the tighter corners not turning sharp enough . The Exotech Front lead weight block looks good but 20 onces ?
Old 11-09-2014, 05:19 PM   #15349
tobamiester's Avatar
Trader Rating: 278 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Switched to 3 gear Mid today. I like it. Shocks mounted on rear of tower.
But with the motor running in the reverse direction, The diff nut seemed to work its way loose. Anyone had similar experience with diff ?
tobamiester is online now   Reply With Quote
Old 11-09-2014, 05:22 PM   #15350
tc5 man's Avatar
How do you compared it to the 4 gear mid gear if you are running on clay ? Like driving wise.
Old 11-09-2014, 05:33 PM   #15351
Never tried the 4 gear Mid actually. Running on a slightly moist Red clay surface using Panther slicks. Running shorty up-front, with ESC/Receiver behind Lipo. 30g TD brass weight under servo.
Not many big jumps on our track so cant speak to articulation in the air with the 3-gear...
Old 11-09-2014, 06:26 PM   #15352
13Maschine's Avatar
I think that makes sense, 3 gear on high bite clay, especially with slicks. Probably much easier to drive right? Less twitchy?
Old 11-09-2014, 06:32 PM   #15353
13Maschine's Avatar
If you are running slicks it's been my experience the track needs to be WET, not just moist. As soon as it gets a little bit dry you get dust, and that's when slicks stop working. Generally the dust forms more in certain spots than others, a lot of times outside the fastest line which is often also where the groove forms. I've found that a low profile tread works better when the dust comes up after slicks stop working. It's tough to chase the track sometimes. When you go out to corner what do you notice about the changes in the track from round to round?
I have the exotek weight and I agree it can be a bit much. I think it would be ok if I was running slicks and they were hooked up. Mostly I use 5g or 10g weights to balance the car out. Do you have scales or how do you balance front to rear?
Old 11-09-2014, 06:36 PM   #15354
tc5 man's Avatar
It does say on the Durango website 4 gear for very high bite( Carpet, Astrotruff ) And 3 gear mid on high traction (Clay) . I would think the 3 gear mid motor would be easier to drive on Clay .
The 4 gear on the Clay yesterday felt like more forward drive than the rear , it was somewhat hard to drive a little twichy at times harder to get lined up to the jumps . On Slicks it sounds like 3 gear Mid gear is the way to go to me.
Old 11-09-2014, 06:42 PM   #15355
tc5 man's Avatar
1st round the Slicks work great the 2nd round still worked good . 3rd round it dry out a bit in the main the Clay dryed out the most it took a while to get constant traction like almost to the end caught me off guard at times . There most of been a little dust cause i blowed my nose and you know lol.
But yea a butch of guys did tell me to go with a little warn or more small treaded tires when its dry.
I did move the rear wheel spacers toward the front later on in the day to get more Rear grip it helped better.
Sucks that the Durango weights are priced so much. I do have little lead weights though 1/2 oz i believe. I don't have a scale.
Old 11-09-2014, 07:47 PM   #15356
303slowdown's Avatar
Trader Rating: 24 (100%+)
I use stick on weights for real cars. 1/2oz should be 7 grams. I run 3 under my servo.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 11-09-2014, 08:46 PM   #15357
Dino_D's Avatar
That is correct. If the track gets a dusty layer, taller treads from barcodes work better. Otherwise it Ions, Typos, Electrons and dirt webs.
If the track is bumpy, you want the standard rims. If the track is smooth the EVO rims or VTR 2.4 rims work better with less sidewall flex.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 11-10-2014, 07:10 AM   #15358
Anyone ?
Old 11-10-2014, 09:22 AM   #15359
tc5 man's Avatar
Are these shorty lipos more than enough Mah rating with a 10.5 motor ? The Heat races i do are 5 min and if im in the B-main 8 mins , A main 10 mins . There 4000mah Shorty 7.4v packs.
Il do practicing also of course .
LND Battery 7.4V 4000mAh 2S Cell 65C Shorty HardCase LiPo Battery Pack w/ 4mm Bullet & Deans Ultra Connector
Part# LND2S4065
Old 11-10-2014, 10:00 AM   #15360
Anyone ?
The motor shouldn't be running in reverse rotation. It's rotational direction in relation to the wheels should be opposite though.
I know other people disagree but I only run the diff nut on the right side, regardless of motor orientation. I always adjust it on the left side only. I learned this with a direct drive on my RC10 in the late 80's. If the adjustment screw was on the right side, it would be more prone to loosen. If the adjustment screw is on the left, it isn't. I've never had a problem since. Where is yours?
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
