Like Tree24Likes
Old 11-04-2014, 09:21 PM   #15316
Dino_D's Avatar
Originally Posted by 13Maschine View Post
is the Durango brass rear hanger that comes with the DEX210v2 marked with -2mm = LRC ??
Yes that is correct.
Also durango has the new front rear hanger with inserts, which allows you to switch antisquat settings quicker.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 11-05-2014, 10:00 AM   #15317
Dino_D's Avatar
Originally Posted by fredswain View Post
The only time I could see running MM4 over MM3 is on a loose, low traction track. Then again I'd just run RM3 there. I went to MM4 on our track once. I didn't really like it. I didn't like it on my 2 previous MM cars (XXX-Cr2, X6^2) either.
If you like MM3 cause it drives flatter, then in Rear motor mode, it would be RM4, not RM3. Cause RM3 will be more like MM4 terms of weight transfer. Am I correct?
Old 11-05-2014, 11:27 AM   #15318
3 gear is 3 gear. 4 gear is 4 gear. They drive the same whether the motor is in front of the rear tires or behind it. The inertial forces are decreased a bit in rear motor since the motor rotation isn't as close to the center of gravity though.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 11-05-2014, 06:25 PM   #15319
RC10Nick's Avatar
Anybody else having problems with their outdrives (the new longer outdrives) wearing out really fast? I put a brand new set of outdrives on my car and paired them with a new set of dog bones. After two race days and a practice day, the outdrives wore out huge notches in them. These notches bind up the dog bones, and tonight halfway through my second practice day, I snapped a CVD. I snapped 3 CVDs over the summer with the same problem, and I'm getting quite fed up with it. I plan on calling TD tomorrow and asking them what gives, but I'd like to know if anyone else has experienced this? I certainly never had this problem when I ran an AE gear diff, even on carpet.
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 11-05-2014, 06:35 PM   #15320
tc5 man's Avatar
Cant say i have im running the stock outdrives on the gear diff . Ran about 4 times on the buggy ., try and reduce the droop on the Rear that will on any scale help with wear on the outdrives and dogbones.
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 11-05-2014, 07:55 PM   #15321
303slowdown's Avatar
Trader Rating: 21 (100%+)
I haven't had the problem either, I have a full year on my gear diff with no issues.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 11-05-2014, 08:45 PM   #15322
Pittster's Avatar
I have the longer outdrives with my ball diff and have done 20 races and no wear and tear so far running both 17.5 and 9.5
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 11-06-2014, 12:13 AM   #15323
tc5 man's Avatar
I been wondering about this i looked at the Manuel again on this buggy and it shows when you mount the shocks Front and Rear. On the Right side the bleeder screw is pointed to the outside and the Left the bleeder screw is pointed to the inside ?
Usually on all my cars i have the bleeder screw pointed to the outside on both sides when i mount the shocks.
Old 11-06-2014, 01:08 AM   #15324
Hi tc5,
Thats because the bore in the plastic caps is not symetrical!
One side is a bit smaler, than the other.
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 11-06-2014, 06:19 AM   #15325
tc5 man's Avatar
Originally Posted by micholix View Post
Hi tc5,
No i mean when you mount the whole shock on the buggy it shows one side with the bleeder screw facing the outside and the other facing the inside .
Old 11-06-2014, 06:26 AM   #15326
I did understand your question.
Sorry, my english is not the best, so may i described it a bit wrong!?
If you have a look at the v2 manual on page 43, they wrote down about that!
Copy out of the manual:"Note smooth witness mark, insert upper ball on this side"
May this bring it better, what i mean?
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 11-06-2014, 09:01 AM   #15327
Dino_D's Avatar
The 4 caps are not the same. There are 2 pairs. 2 of them have screws facing left, and 2 of them have screws facing right. All you need to do is swap 1 cap of your fronts with your rears, and that should cure the problem. Cause you have 2 lefts on the front and 2 rights on the rear.
Old 11-06-2014, 09:59 AM   #15328
RC10Nick's Avatar
I called up hobbico support and the rep I spoke with told me they've had some issues lately with their outdrives. He's sending me new outdrives plus a new set of driveshafts. I'm bummed that I can't race my buggy this weekend (I've got other cars and it's not a points race, so no big deal), but I am happy with the support from Hobbico.
JT RC Products
Old 11-06-2014, 03:58 PM   #15329
That's good to know the support was good.
Ryan Borgheiinck
Old 11-06-2014, 05:52 PM   #15330
tc5 man's Avatar
What is different looking about the shock caps i don't notice it ? It does seem like when i mount the shock on with the bleeder screws toward the inside of the buggy i get more treads on the locknut .
I was looking at a butch of pics of the buggy online and most of them have the shocks mounted with the bleeder screws pointing outside of the buggy. I tried that but there is hardly any treads when you fully tighten the small locknut.
Its on page 44 in the manuel.
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
