Like Tree26Likes
Old 10-20-2014, 09:51 AM   #15241
Shawn_S's Avatar
Trader Rating: 18 (100%+)
110mm might be a a little short depending on what configuration you plan on running.
A run of the mill 4600mah shorty probably gets me well north of 15mins of run time with a 8.5t.
Tekno NT48.3 | NB48 | EB48.4 | SCT410.3
Team Durango DEX410v5 | DEX210v3
Mugen MBX-GT8 | GT8-E
Shawn_S is offline   Reply With Quote
Old 10-20-2014, 10:04 AM   #15242
fq06's Avatar
Yeah, it all depends on where you place the esc (front, back or side) and if you are running mid or rear motor.
I use a piece of string when wiring up a new kit and lay it out to get a length.
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 10-21-2014, 05:59 AM   #15243
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
+1 for String Theory. Using a string is easiest way to measure. Make sure you leave some slack.
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 10-21-2014, 10:25 PM   #15244
tc5 man's Avatar
Guys running the 4 gear mid motor i noticed that the bottom of the gearbox the Front bottom is locked down into the chassis more than the Rear is that normal with mid gear ? I used the right screws and spacers and followed the manuel. Thinking using the little bumper and the spacers underneath the rear of the gearbox since it raises it its normal than.
I know from RM 2wd at least that ive own before the bottom of the gearbox locks into the chassis leveled.
Durango DEX210 Thread-win_20141022_011429.jpg   Durango DEX210 Thread-win_20141022_011449.jpg
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 10-21-2014, 11:11 PM   #15245
seems that you put the little rear bumper in the wrong space
the bumper should be put in further lower
Marco926 is offline   Reply With Quote
Old 10-21-2014, 11:49 PM   #15246
tc5 man's Avatar
Oh i see now thanks. Just did that and its locked into the chassis Front and Rear bottom of the Gearbox now . The Manuel is a vagued on showing that .
Il take pics of the right way later tomorrow.
Old 10-22-2014, 07:25 AM   #15247
Hey guys... I'm back... lol
Just got my dex210 in the mail today, and the electronics coming later this week. What parts are more prone to break? My LHS doesn't carry Durango and I will have to get parts from amain or tower.
thechuckles8910 is offline   Reply With Quote
Old 10-22-2014, 12:24 PM   #15248
Devin's Avatar
What ball diff maintenance should I perform over the winter. I plan to change the bearings. Do the balls wear out as well?
Was going to just clean the dickens out of it and treat it to new bearings. Anything else these buggies need to get ready for a new season?
@the chuckles, my track is easy on cars, but I don't recall anyone breaking anything other than rear wings and a stripped spur gear on the Durango's. I have one of everything and haven't needed it. My SC is way harder on the equipment.
Devin is offline   Reply With Quote
Old 10-22-2014, 12:47 PM   #15249
Shawn_S's Avatar
Front a-arm, wide open in exposed spike. Truggy knocked the pipe off.
Spur gear, random ball of solder found its way into the spur, chewed it up.
Spur gear cover, broke at the top screw hole, cracked at bottom
And pulled the rear shock shaft out of the shock eyelet.
Old 10-22-2014, 01:01 PM   #15250
tc5 man's Avatar
I would just get the gear diff i just bought one . Since you gotta rebuild the ball diff .
Old 10-22-2014, 01:14 PM   #15251
So how many of you are running the gear diffs? I have the v2 with the ball diff and looking at set-ups online I've only seen lutz running a gear diff. Wondering if it's worth the money to get the gear diff
For those that are running the gear diff, I'm running on an indoor clay track, small/medium, tight turn with alot of off camber, and medium traction. What fluid weight would you recommend?
BensPro2 is offline   Reply With Quote
Old 10-22-2014, 01:21 PM   #15252
Dino_D's Avatar
Beside gear cover, and the smaller idler gear bearing, Its a pretty strong car. If you are really worried, gear cover, front and rear arms, suspension holders, rear hub - but I haven't broke anything yet.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 10-22-2014, 01:23 PM   #15253
tc5 man's Avatar
On higher traction a gear diff holds up better you just need to tune the diff oil to your likening so it doesn't diff out to much . I just know this from running a ball diff than a gear diff on my T4.1 I sold a while ago .
Old 10-22-2014, 01:24 PM   #15254
Dino_D's Avatar
start with 1-2k. Start with 2k first. I find the ball diff better on med traction tracks. Gear diff if high traction or carpet.
Old 10-22-2014, 01:27 PM   #15255
tc5 man's Avatar
I meant to ask about what weight diff oil for the gear diff ? I'm thinking 4000w, 5000w since il be running on carpet and clay .
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
