Like Tree23Likes
Old 10-09-2014, 09:08 AM   #15211
Dino_D's Avatar
Originally Posted by tc5 man View Post
What spare parts should i get for this buggy im thinking spur gears, front and rear arms ?
Also turning the gearbox around to the driver side with the 4 gear mid motor would i need to set the throttle to reverse direction on the radio or just normal ? Or it doesn't matter .
I'm going to run a 10.5 track star motor sensored .
If you are talking about your radio (servo reverse) it really depends on the ESC and radio. Some ESC like it when you reverse this setting, some don't.
As for the car, you shouldn't need to set the ESC or motor to reverse. If you do, either you are running the gears wrong or the motor plate is on the wrong side. MM4 is 4 gear mid motor with motor plate on driver side (left). MM3 is 3 gear mid motor, passenger side (right)
The track star is a decent motor for indoors. Just run a bit of turbo (not boost) about 10 degrees so your top end is comparable to the 8.5.
Spare parts? The car is really strong. I highly doubt you would break anything. If anything, I would suggest the suspension holders as they take a licking and start to develop slop over time. Drive pins for hexes. They are not the clamping type and you can easily loose them. Also get some extra rear wings. Spare ball cups maybe. And the small bearing near the slipper. That is the smallest bearing in the gearbox and it tends to go first.
If you want to go overboard, you can get front and rear arms, and shock towers.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 10-09-2014, 02:31 PM   #15212
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
I think I just realized I put my mm4 setup back together wrong.
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 10-09-2014, 02:34 PM   #15213
tc5 man's Avatar
But the Manuel on the V2 edition shows the Mid motor 4 gears on the drivers side with the motor plate/slipper clutch on that side also .
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 10-09-2014, 02:44 PM   #15214
In 3 gear (MM or RM) the spur gear should be on the right side. In 4 gear (MM or RM) it should be on the left.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 10-09-2014, 03:25 PM   #15215
Dino_D's Avatar
Maybe we shouldn't use driver side. LOL
For those in the UK or Asia, it's the opposite way.
It is the left of the car when looking at the rear of the buggy for MM4.
Old 10-09-2014, 03:26 PM   #15216
tc5 man's Avatar
Yea i was Looking at alum inner suspension blocks anyways . And Alum clamping hexs from Exotek 14mm . Bearings yea also .
I ran the track star motor on my T4.1 but never added timing since my Novak GTB esc doesn't have turbo or timing could do Manuel timing on the motor though .
Old 10-09-2014, 06:46 PM   #15217
Stop listening to Manuel!
Old 10-10-2014, 08:32 AM   #15218
Trader Rating: 137 (100%+)
Get the updated arms before they go out of stock for six months again. Reason why I switch to AE. Durango parts support is the absolute worst in this industry.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-10-2014, 09:05 AM   #15219
tc5 man's Avatar
I have the V2 model of this buggy . There the updated arms and other things .
Most shops online have the replacement parts and upgrades in stock most of time for Durangos not sure what you mean .
Old 10-10-2014, 11:00 AM   #15220
Shawn_S's Avatar
Trader Rating: 18 (100%+)
Does it have to be on the left for RM4? I just reversed my esc. Car felt good but maybe a little off? First time rubbing anything other than 1/8th in a while.
Tekno NT48.3 | NB48 | EB48.4 | SCT410.3
Team Durango DEX410v5 | DEX210v3
Mugen MBX-GT8 | GT8-E
Shawn_S is offline   Reply With Quote
Old 10-10-2014, 12:39 PM   #15221
If you are running 4 gear and the spur is on the right, you are running your motor in reverse.
Old 10-10-2014, 01:24 PM   #15222
Dino_D's Avatar
If you reverse the motor direction on the ESC and you have manual timing +++, you might be getting less power in forward than full reverse unless you turn the timing the other way. Most motors have adjustable timing, but some do not. And if you can't put it at 0 timing or reverse the timing you are just making yourself at a further disadvantage.
It's better you have the motor plate the right way around.
Old 10-13-2014, 11:59 AM   #15223
13Maschine's Avatar
I think we just talked about this a while back but I somehow failed to save the model number etc. What snap ring pliers do you guys like for the differential cir-clip?
These ones?
http://www.amazon.com/Channellock-92...ap+ring+pliers
Old 10-13-2014, 03:34 PM   #15224
tc5 man's Avatar
Who makes sway bars for the rear end on this buggy ? I can't find them anywhere . Are they needed on high traction for this buggy .
Old 10-13-2014, 06:53 PM   #15225
Dino_D's Avatar
No there isn't a sway bar kit for the 210. But even Jorn doesn't run sway bars on high traction carpet and still wins a lot of the EOS indoor races.
St Ives RC Club B4Bandit Australian Racing 16563 Today 04:32 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 7 (2 members and 5 guests)
30Tooth, Dopkal
