Like Tree23Likes
Old 10-08-2014, 09:09 AM   #15196
rcjunky1's Avatar
I'm not a fan of the exotek quality, its sloppy and needs mods for the plastic chassis
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 10-08-2014, 09:49 AM   #15197
That's weird. I've been very happy with everything I've ever gotten from Exotek.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 10-08-2014, 10:53 AM   #15198
tobamiester's Avatar
Trader Rating: 275 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
+1
I just installed the Exotek RF hanger as I busted the plastic one on the v2 first time out. Yes for this part you do need to make it work on plastic chassis but at least its an available solution...
tobamiester is offline   Reply With Quote
Old 10-08-2014, 01:53 PM   #15199
Pittster's Avatar
Originally Posted by Dino_D View Post
The adjustable ones. I have been testing these since Aug in a few of my cars.
There were available at Tower at the end of Aug. as a few local drivers in my area were able to order them up. I gave them the part number when they saw it on my car during a practice session.
They are a lot stronger than the plastic ones and use the numbered inserts similar to the DEX410 to change the front kick up or anti squat settings. If the inserts get worn out or damaged, its easily replaced. Depending on the adjustment number you use, you can use either the LRC or HRC blocks in the rear. You still need to remove the rear LRC or HRC block to change the inserts but at least you don't need to remove the entire front rear block. Which makes adjustments at the track much quicker. Keep in mind you will also need those hinge pin pivot balls that go into those plastic inserts to make them work.
I don't have the instructions in front of me to tell you what settings are what. But its definitely not the same as the stock settings.
Stock gives you 3, 1.5 and 0 with HRC. -2mm LRC adds 0.2 to each setting
The new part allows for different ranges. You won't get 3, 1.5 and 0, but rather 2+, 2, 1.8, 0.5 or something like that.
I can chime in on the exact settings later when I get home. Or unless someone has it handy with him.
Thanks Dino for that, really like the ability to change inserts never had a issues with the durability in my 410 with them.
Originally Posted by tobamiester View Post
+1
Exotek one looks OK I run there hubs etc. Just wondering what you had to make work for the plastic chassis ? I run the Type B Dimec20 chassis, are the holes not right on the exotek ?
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is online now   Reply With Quote
Old 10-08-2014, 02:46 PM   #15200
tc5 man's Avatar
Anybody know ?
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 10-08-2014, 03:05 PM   #15201
EbbTide's Avatar
Trader Rating: 32 (100%+)
The type B chassis has a bit more material in the rear on the plastic Tybe B chassis. So chances are, the RF hanger won't sit on the chassis very well with the extra plastic back there. It should fit fine on the stock chassis, but it would probably need a workaround for a type b plastic chassis. Like shaving down some plastic or potentially using a slightly longer screw to hold it in place.
::: Tekno EB48SL ::: HPI Blitz ::: Kyosho RB5 SP2 WC :::Team Durango DEX210 v2 ::: Team Durango ExoDex210 :::Tamiya TB03r/TRF418-ish :::
EbbTide is online now   Reply With Quote
Old 10-08-2014, 03:56 PM   #15202
Running the Alum v2 chassis so it dropped right in..Sorry
edit: there are pictures of mods you need to make for the exotek on on the product page http://www.exotekracing.com/dex210-r...ith-shims-lrc/
Old 10-08-2014, 05:29 PM   #15203
Trader Rating: 62 (100%+)
Originally Posted by tc5 man View Post
I'm having a bad binding issue with the gear box on the V2 version . Seems like when i tighten up the screws on the top not bottom of the gearbox it binds up the top shaft when it's against the motor plate ? It's the right size screws and I'm not over tighting them .
The bearing that goes into the support mounting piece that snaps onto the gear box is not flush it won't though when i stick the top shaft spacer in .
Do you have spacer 310459-4 in place. Also check your idler spacing. Sorry can't help much more with out having it in my hands.
N.W Hobbies
M.Pease
The Wease is offline   Reply With Quote
Old 10-08-2014, 07:43 PM   #15204
tc5 man's Avatar
I figured it out now no binding . I do have a question on the 3 gear mid gear do you build it as a rear motor with the bigger idler gear in the middle ? and just flip the gearbox to the left side on the chassis like the 4 gear mid motor in the Manuel shows ?
The Manuel only shows the Rear motor and 4 gear mid motor gearbox setup .
Old 10-08-2014, 07:44 PM   #15205
rcjunky1's Avatar
I just shaved down the little tabs on the spacers to fit. For droop, definitely shave the arm, not the chassis, it makes the droop stops too flexy
Team Durango Canada
Old 10-08-2014, 08:04 PM   #15206
Devin's Avatar
I figured it out now no binding . I do have a question on the 3 gear mid gear do you build it as a rear motor and just flip the gearbox to the left side on the chassis like the 4 gear mid motor in the Manuel shows ?
What did you do? I am having the same problem with binding in the gearbox.
Devin is offline   Reply With Quote
Old 10-08-2014, 08:12 PM   #15207
tc5 man's Avatar
I sanded the edges down a little on the side in the inside of the gearbox . Than the support piece that snaps onto the gearbox with the bearing inside got flush now . And i push in the medal rods into the gearbox more .
Make sure you get the idler gear rod were the slipper goes onto all the way in to the small bearing in the gearbox .
And don't over tighten the screws into the gearbox just snug .
Old 10-08-2014, 08:45 PM   #15208
ekt
ekt's Avatar
For MM3 the layshaft bearing is mounted in the opposite side of the gearbox, compared to the MM4 layout. The layshaft and motor plate are also mounted on the other side.
For a detailed reference, refer to the v1 manual http://www.team-durango.com/pdf/manu...n%20Manual.pdf
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 10-09-2014, 08:10 AM   #15209
tc5 man's Avatar
Oh ok thanks . I'm going to try out the 4 gear mid motor first since im going to run on high traction clay/carpet .
Old 10-09-2014, 08:11 AM   #15210
tc5 man's Avatar
What spare parts should i get for this buggy im thinking spur gears, front and rear arms ?
Also turning the gearbox around to the driver side with the 4 gear mid motor would i need to set the throttle to reverse direction on the radio or just normal ? Or it doesn't matter .
I'm going to run a 10.5 track star motor sensored .
St Ives RC Club B4Bandit Australian Racing 16564 Yesterday 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
