Like Tree43Likes
Old 10-06-2014, 09:02 AM   #15181
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
if you are looking on the cheap for a high power ESC, send me a PM. Got a Speed Passion GT2.0 Pro and Programmer here that I won't be using (switching to all viper in offroad). ESC is powerful enough to be used in 4x4 SCT with 4 pole motors like the HW 3656SD when set right (this is what I used in my daughters SCT410 for a bit). Programmer will let you put whatever sotware you want for blinky or mod racing via connection to the pc.
As for going cheap on a servo, I have found that I like the Airtronics 94358 servos. I have found those used for about $25 and they do .10 transit at 200oz of torque. Its actually what I used in my daughters dex210 and I got it for $25 I believe shipped.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 10-06-2014, 09:33 AM   #15182
Dino_D's Avatar
Originally Posted by Devin View Post
Someone at the track informed be about drag brake. I'm running a little bit now, and it helped level out my jumping quite a bit. I can likely play with it to get it flatter still, but it was now within a consistently save-able range.
I always like to run drag brake. You can go in deeper into a corner and still be able to make the turn without running wide, and adjust the steering as you need it with the drag brake.
Low grip run 5 or 10%. High grip dirt, go to 15%. Carpet you can use around 20%
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 10-06-2014, 03:02 PM   #15183
Shawn_S's Avatar
Trader Rating: 18 (100%+)
Does anywhere State-side have v2 front arms instock? (TD330594) Need 'em for this weekend.
Tekno NT48.3 | NB48 | EB48.4 | SCT410.3
Team Durango DEX410v5 | DEX210v3
Mugen MBX-GT8 | GT8-E
Shawn_S is offline   Reply With Quote
Old 10-06-2014, 07:17 PM   #15184
Trader Rating: 62 (100%+)
Not that I'm aware of . A main says Oct 9th . I had to get V1 cause I broke an arm over a month ago and V2s have been on back order for sometime now
N.W Hobbies
M.Pease
The Wease is offline   Reply With Quote
Old 10-07-2014, 08:53 AM   #15185
tc5 man's Avatar
What's a good starting point for gearing with stock spur gear on a 10.5 motor ? It's going to be ran on indoor tracks not that big .
And who makes a Alum servo horn that is the same as the stock plastic one ?
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 10-07-2014, 09:15 AM   #15186
Dino_D's Avatar
You can use the plastic or alum TLR22 horn. But the stock plastic one holds up pretty good too.
Old 10-07-2014, 11:39 AM   #15187
tc5 man's Avatar
Ok thanks . What about gearing on a 10.5 with the stock spur gear at indoor tracks that are not to big ?
Old 10-07-2014, 12:43 PM   #15188
Dino_D's Avatar
Which is the stock spur? I think the original v1 comes with 87T and the v2 comes with 81T.
Normally I prefer to run the 81T spur vs the 87T spur.
Gearing:
8.5T Motor
81T spur + 22T (indoor) 23T (outdoor) or 24T pinon (big track)
87T spur + 24T (indoor) 25T (outdoor)
10.5T Motor
81T spur + 25T (indoor) 26T (outdoor) or 27T pinon (big track)
87T spur + 27T (indoor) 28T (outdoor)
Old 10-07-2014, 12:53 PM   #15189
tobamiester's Avatar
Trader Rating: 281 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Gearing:
8.5T Motor
10.5T Motor
Yeah 81 is stock in v2. I'm running 81/27 w/ 10.5T.
tobamiester is offline   Reply With Quote
Old 10-07-2014, 01:03 PM   #15190
tc5 man's Avatar
It's a 81t than I have the V2 model . That's a high tooth pinion !
I guess il buy 23t, 24, 25 t pinions .
Old 10-07-2014, 10:12 PM   #15191
Pittster's Avatar
Can anyone affiliated with Team Durango comment on how far these Rear block's are from being available. Dino_D or Ekt ??
I have destroyed a few Type B RF Blocks now lucky there cheap
SUSPENSION HOLDER ALUMINIUM: RF
Part #: TD330565
This RF Suspension Holder is precision manufactured from aluminium and will provide the perfect support for the Rear-Front suspension assembly of your vehicle.
Features:
Premium quality aluminium for light racing weight and added precision fit - Specially designed insert slots for fast and easy set-up adjustments in minutes - Fast height changes to your rear Hinge Pins for a wider range of tuning options - Anodised in Team Durango Olive for Pro race team looks and long-lasting durability
Includes:
1 x Suspension Holder RF per pack
http://www.team-durango.com/part-inf...artNo=TD330565
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEDLT
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 10-08-2014, 08:33 AM   #15192
Dino_D's Avatar
Part #: TD330565
Features:
Includes:
The adjustable ones. I have been testing these since Aug in a few of my cars.
There were available at Tower at the end of Aug. as a few local drivers in my area were able to order them up. I gave them the part number when they saw it on my car during a practice session.
They are a lot stronger than the plastic ones and use the numbered inserts similar to the DEX410 to change the front kick up or anti squat settings. If the inserts get worn out or damaged, its easily replaced. Depending on the adjustment number you use, you can use either the LRC or HRC blocks in the rear. You still need to remove the rear LRC or HRC block to change the inserts but at least you don't need to remove the entire front rear block. Which makes adjustments at the track much quicker. Keep in mind you will also need those hinge pin pivot balls that go into those plastic inserts to make them work.
I don't have the instructions in front of me to tell you what settings are what. But its definitely not the same as the stock settings.
Stock gives you 3, 1.5 and 0 with HRC. -2mm LRC adds 0.2 to each setting
The new part allows for different ranges. You won't get 3, 1.5 and 0, but rather 2+, 2, 1.8, 0.5 or something like that.
I can chime in on the exact settings later when I get home. Or unless someone has it handy with him.
Old 10-08-2014, 09:15 AM   #15193
tc5 man's Avatar
I'm having a bad binding issue with the gear box on the V2 version . Seems like when i tighten up the screws on the top not bottom of the gearbox it binds up the top shaft when it's against the motor plate ? It's the right size screws and I'm not over tighting them .
The bearing that goes into the support mounting piece that snaps onto the gear box is not flush it won't though when i stick the top shaft spacer in .
Old 10-08-2014, 09:20 AM   #15194
Part #: TD330565
Features:
Includes:
Other option http://www.exotekracing.com/dex210-r...ith-shims-lrc/
Old 10-08-2014, 09:37 AM   #15195
tc5 man's Avatar
This is a mid motor build if that matters .
St Ives RC Club B4Bandit Australian Racing 16575 11-18-2017 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
