Like Tree23Likes
Old 11-03-2011, 08:30 AM   #1501
rcman182006's Avatar
Send a message via Yahoo to rcman182006
For those looking to try and run 25* front caster
http://www.team-durango.com./blog/?p=4622
-=-Charles Kilbarger-=-
Serpent SRX2 MM - D4 17.5 - Hobbywing Justock
AE RC10 Team Car - RevTech 17.5 - Hobbywing Justock
#NoChuck2015
rcman182006 is offline   Reply With Quote
Old 11-03-2011, 08:52 AM   #1502
twelvegauge's Avatar
Send a message via AIM to twelvegauge Send a message via MSN to twelvegauge
I am having pushing issues. I tried a few things to much to list right now but it pushes in and has very little on power steering.
I have the 4 gear trans, 1.5 kick, 0 deg tow and 30 deg caster. The springs are light blue rear dark front 40w & 30w oil. I also have 1 spacer in camber link mount.
0 on the front axle block with 2 spacers front and behind.
www.sycrcmaraceway.com
Maple Acres Raceway, SYC R/C Racing
I-Lap Timing System, R/C Scoring Pro
Replacement fans for esc's & heat sinks
biscayne348@gmail.com or 630-935-0132
twelvegauge is offline   Reply With Quote
Old 11-03-2011, 09:00 AM   #1503
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Matt Howard View Post
I think he meant no one has it in stock, as in available to buy
oh..haha... HAHA.. yeah, you're right. Now that's a classic To the guy that asked... nobody has it in stock because it's sold out.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-03-2011, 09:07 AM   #1504
Super Moderator
here is one piece of the push puzzle
Durango DEX210 Thread
the other , is that you are running the 4 gear. Switch to the 3 gear and fix your spring rates, and you will be good.
- RCSpecialties -
Old 11-03-2011, 09:10 AM   #1505
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
go to 3 gear kick up, add 1 oz behind the servo.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-03-2011, 09:13 AM   #1506
billjacobs's Avatar
Trader Rating: 53 (100%+)
Default issues with build
I am having issues with my dex210 build. If you join the side pods and the servo side pieces (that clamp down on the steering rack,) the chassis holes do not line up. The chassis holes line up perfectly under the steering rack + servo holders, and they line up perfectly under the side pods, each by themselves. If you install the steering rack and servo side pieces, the holes under the side pods are off by about a mm.
Has anyone else experienced this. What is the solution?
billjacobs is offline   Reply With Quote
Old 11-03-2011, 09:16 AM   #1507
Super Moderator
Everybody has this issue i believe, and it has been covered in this thread already... I had to unscrew most of the lower screws up front most of the way, and get all the screws started together before I could snug any of them down.
- RCSpecialties -
Old 11-03-2011, 09:16 AM   #1508
Super Moderator
what's this?
- RCSpecialties -
Old 11-03-2011, 09:35 AM   #1509
Team Tekin
Randy_Pike's Avatar
Originally Posted by Cpt.America View Post
what's this?
He used "kick up" in lieu of anti squat.
Old 11-03-2011, 09:44 AM   #1510
Matt Howard's Avatar
you mean 3 "degree" kickup, you said 3 "gear" kickup
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-03-2011, 10:11 AM   #1511
Crazy Carl's Avatar
Trader Rating: 7 (89%+)
Randy how about a nice starting place with the rs speedo. 10.5 motor
100' straight
Crazy Carl is offline   Reply With Quote
Old 11-03-2011, 10:12 AM   #1512
hopsing's Avatar
Trader Rating: 13 (93%+)
Ran my 210 for the first time last night....woo hoo!!
Even with way too thick of rear oil (40wt Losi oil cause I had some when I put the car together), the car was great out of the box.
A drop to 32.5wt in the rear (30wt might be even a little better) and it was even better.
A change in the lower front shock position got me some more off power mid corner steering (moved the bottom to inside hole on arm)
Set ride height to 24mm all the way around...kit springs...3 gear rear motor....med grip clay track.
I have 5 TOTAL runs on this car and am already within 3-5 tenths on average of the fast guys that run the layout 2-3 times a week (this was my 2nd time on the layout and first with the 210....and I wasnt even close with my "other" car)
Some more time and tuning on the car it will be stellar (it really already is!)
On to the talk of diff problems.....I did have an issue with mine during practice right after the car's second run.....diff started slipping BAD (not barking, just slipping like a slipper), yet the diff action was SUPER tight (but still smooth)
After taking off a million screws to get the trans out I found the diff gear was able to wobble slightly yet the diff felt really tight. Disassembled the diff to check the thrust assembly and noticed the snap ring didnt look like it was seated correctly like when I first put it together (you could tell because the open end of the clip was really close together) Took a flathead screwdriver and "twisted" it in the opening while pushing on the snap ring and it "clicked" into place. Somehow I may have not got the snap ring fully seated in the groove inside the outdrive and when I tightened the diff screw it pushed on the assembly and actually pushed the snap ring out of the groove....which would cause everything to "squish" together and bind up (why the diff was soo tight) as well as try to force the outdrives away from each other (which is probably why the diff gear was now wobbly).
So, MAKE SURE THE SNAP RING IS FULLY SEATED IN THE OUTDRIVE AND LOCKED INTO THE GROOVE TIGHT!!
I suspect this may be everyones problem with the diffs slipping..... after my "fix" I put on 3 more runs with no issues, a super smooth diff and no slipping or barking.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 11-03-2011, 10:19 AM   #1513
I had to do the same and tighten the screws in a cross pattern to get it to tighten evenly.
Old 11-03-2011, 10:20 AM   #1514
My bad, yes anti squat .
Old 11-03-2011, 10:22 AM   #1515
hopsing's Avatar
Really need your complete set up like where shocks are mounted, bump steer spacers, where hubs are mounted, trailing front axle or inline, etc...to give more accurate help.
But to start...
Going to 3 gear trans should help..... but first, I would go to 35wt in the front shocks, set ride height front and rear to 24mm, if you are running the lower front shock mount outside on the arm then move it to the inside hole on the arm. I'm running 3 deg anti squat in the rear with 3 deg total toe in (0 deg insert on rear hubs) And I still run the kit springs.
I run on a med grip clay track and my car was really easy to drive.
Steve Butts
St Ives RC Club B4Bandit Australian Racing 16564 Yesterday 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
