Durango DEX210 Thread >
Like Tree80Likes
Old 09-19-2014, 10:33 AM
  #15076
Dino_D's Avatar
Originally Posted by Cain
to confirm you are using the metal cover with the regular durango spurs or with the avid in RM?
Metal cover on std durango spur with AE slipper pad in RM. The metal cover can't fit with the Avid slipper on.
Regardless which config, avid slipper needs avid cover.
Anyhow, you have more rear grip in RM. I think slipper performance of the avid is better in MM mode, when you want the slipper action to be smoother. Sure the avid is great in RM as well, but the covers just don't last, hence why I opted for the metal one and using a standard slipper.
Dino_D is offline
Old 09-19-2014, 06:51 PM
  #15077
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
thanks for info. I agree the covers go to hell around the screw holes. really sucks.
Cain is offline
Old 09-19-2014, 07:02 PM
  #15078
Trader Rating: 55 (100%+)
Use longer screws and put a old shock oring on each screw problem solved!
DR.Vanostrum is offline
Old 09-19-2014, 09:38 PM
  #15079
re-do73's Avatar
Plan B chassis conversions are in production! Will have at least 3 available by monday. PM for details
re-do73 is offline
Old 09-20-2014, 12:47 AM
  #15080
Looks very good!
Do i see it right, that it is an +10 chassis?
What program do you use for the construction of your files?
micholix is offline
Old 09-20-2014, 06:37 AM
  #15081
RC10Nick's Avatar
Looks nice! I just got my cnc router wired up yesterday and seeing what you've created is really motivating me to finish up mine!
RC10Nick is offline
Old 09-20-2014, 08:52 AM
  #15082
re-do73's Avatar
Originally Posted by micholix
Looks very good!
Yes, plus 10 chassis. I use solidworks for all my designs.
@ Nick, good luck!!! it's a long journey of fustration and headaches, but when you cut your first part it is worth it!!!!!
re-do73 is offline
Old 09-20-2014, 11:01 AM
  #15083
psl
Default V2 build
When building the V2. I have a base set up sheet. It says to use maximum droop for the front and rear arms. Does it mean droop screws fully down or up. If I let the front arms fully droop my front ride height is in the mid to high 20's. Am I doing something wrong with the build? The set up sheet suggest a 19 ride height for the front.
psl is offline
Old 09-20-2014, 11:40 AM
  #15084
Instructions are just for basic assembly. Set ride height with droop screws per setup you want to start with. I'm running 23 front 25 rear on mine at the moment.
Wanderer77 is offline
Old 09-20-2014, 04:25 PM
  #15085
ekt
ekt's Avatar
For maximum droop, set the screws so that the arms are allowed full travel. Ride height is adjusted with the preload nuts on the shocks, refer to this video for setting your ride height https://www.youtube.com/watch?v=tKTfEGZom4Q
ekt is offline
Old 09-20-2014, 08:19 PM
  #15086
tobamiester's Avatar
Trader Rating: 360 (100%+)
Just built a v2. Have an issue, maybe an old one.
Driveshaft on left appears to be hitting the diff-nut (in the outdrive on the left) when holding the car off the ground.
I've put the TD330377 Alum hubs on it. I'd tried it with the stock v2 hubs and it didn't seem to be any better. Any ideas?
tobamiester is offline
Old 09-21-2014, 05:09 AM
  #15087
ekt
ekt's Avatar
Sounds like your diff may not be tight enough or you have too much camber.
ekt is offline
Old 09-21-2014, 07:15 AM
  #15088
Solved it. CVA Pin installed incorrectly lol..
Old 09-21-2014, 07:50 AM
  #15089
Not to disagree with the Team Durango guys, I take a slightly different view on "ride height" that I should've fully explained.
When I think of droop screws I am thinking what I call "mechanical ride height". By allowing more or less mechanical ride height, you can influence how much weight shifts around. For example, if you allow "full droop" in the rear, then as you decellerate the rear is allowed to come up higher and more weight transfers to the front. If you limit the amount of droop in the rear, then you can keep the weight lower on decelleration and transfer less weight to the front. The same effect happens left/right across the car as you corner.
When adjusting the preload collars on the shocks, I am adjusting "suspension sag" and spring preload.
My "running ride height" winds up being a net effect of these two. Maximum and minimum "mechanical ride height" can also be adjusted via shock travel limiters, but I'm sure that's covered elsewhere.
On my track and for my driving style...I prefer to minimize weight transferring around.
I have my max ride height set at 23/25. Loaded up race ready, I run ~1mm sag in front and ~2mm sag in rear. My running ride height ~22fr/23rear.
I hope all of that makes sense.
Old 09-21-2014, 09:48 AM
  #15090
keepitsteel's Avatar
Awesome thank u Wander 77 and 13machine. I'll try both. For now I used a exotek 20 gram weight in the back through the lower wing mount using a zip tie. Is it me or does the mm3 (even on loose clay/dirt) still feel like it hauls out of the corners more than mm4. I guess the polarity of the motor has a lot to do with it.
keepitsteel is offline
