Like Tree23Likes
Old 09-09-2014, 07:30 PM   #15016
I just went back to the stock V1 chassis and the HRC rear with V2 suspension in MM. This is an awesome combination. More importantly I'm back to the original body!
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 09-09-2014, 11:55 PM   #15017
Hi fredswain,
Could you tell me, on what surface will you run with this configuration?
Thx in advance
Mike
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 09-10-2014, 06:57 AM   #15018
Originally Posted by 13Maschine View Post
Has anyone run the Exotek Graphite chassis? Comments, love it, hate it etc. Thanks!
Dave
I purchased two about a two months ago when Exotek had them marked down to $45. I have a V1, with the aluminum chassis. The Exotek is noticeably lighter and the quality is top notch. I can't really give a direct comparison to any of the +8 Durango chassis's because I never owned one. I like it but actually wish it was the normal/stock shorter length. The +8 takes away a bit of steering, like all longer chassis's do. I kind of got pretty accustomed to the more nimble feel of the stock/shorter chassis but in truth haven't done much setup change to bring more steering back, etc. I'm completely happy with it for the great price I paid and the quality. I purchased it at the time because my aluminum one was warped noticeably. On a flat surface, pushing down on the center of the car, both the front and rear ends of the car would still be about 1/8" or a bit more off the surface, the front kick-up bend was also showing alot of wear and thinning.
WailinOnYa is offline   Reply With Quote
Old 09-10-2014, 07:23 AM   #15019
Originally Posted by micholix View Post
Hi fredswain,
Thx in advance
Mike
I'm currently setting this up for carpet since our dirt track closed down. I run MM3 with the rear shocks in front of the arms, inline steering, and 15 caster up front. No rear kick with 3 rear toe. This is the same setup I ran on dirt except I had the +8 Dimec20 chassis. I honestly never liked the +8 chassis. It could have been the flex or maybe it was having a hideous cab forward body. I don't know. I run the rear hubs all the way back so the drive shafts when viewed from above make a straight line. I have no idea why other people can't get rear grip and have to resort to MM4 or hubs forwards?
Old 09-10-2014, 03:46 PM   #15020
Surely that car acts unpredictable, compared to a well setup MM4 car, My car in MM4 has loads of steering and the grip was pretty decent and jumps very well! I dont think any pros run MM3?
Team Durango - DNX8 - DEX8 - DEX410v4 - DEX210v2 - Alpha Lutz WE - VP PRO - Futaba - Hudy - Orion
av4625 is offline   Reply With Quote
Old 09-10-2014, 04:12 PM   #15021
I don't care what the "pros" do. I don't copy others. I know how to think for myself. I've found that MM3 actually drives far more neutral and predictably than MM4. The problem with rear grip on MM cars is a based on weight on the drive wheels, not where that weight is located in relation to the rear wheels. Motor rotation compensation is a bandaid of sorts since it artificially transfers weight to a place where there should be a higher amount of static weight. I'd prefer the car not transfer any weight artificially. Here's something to think about. Why do the pros constantly change their setups if those setups are so good? How can everyone that ever tries some new setup sheet that gets posted suddenly claim that the new setup is the setup to have over and over again? The simple reality is that either setup doesn't matter at all (unlikely), or they are going back and forth between equally compromising setups (most plausible). They can't all be good. I find that with a good setup, going track to track requires small changes. If you need to start over, you should really question your entire setup technique.
Old 09-10-2014, 05:48 PM   #15022
RC10Nick's Avatar
I run mm3 on dirt with my 210 as well. It's quite the opposite of unstable. It's about the easiest car I've driven outside of a 4wd. Without the excessive weight transfer that occurs in mm4, the car is much more predictable and stable. But like fred says, you gotta get the weight right first.
On the topic of a shorter chassis, I've actually been contemplating going back to a shorter chassis. I never really thought I gained anything going longer, and even though it's been over a year since I had the original length chassis, I remember it being more nimble. Once I get my cnc router churning out parts, one of the first things I plan on making is shorter chassis with the same layout as my current hand made g10 +8 chassis. Should be interesting.
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 09-10-2014, 07:01 PM   #15023
rcjunky1's Avatar
A guy on oople had some pimp side pods made to rotate the pack 90*, they were super trick
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 09-10-2014, 07:40 PM   #15024
Since I'm setting the car up for carpet now, let's look at why MM3 is the perfect choice. First what is a carpet track but just a smooth onroad track with a few wooden jumps added. It's smooth and has a decent amount of grip. What are the fastest onroad cars? There are the pan cars (F1, LeMans, etc). These are all 2wd mid motor with a counter rotating motor in relation to the wheels. No anti squat or rear toe. They are solid rear axles after all but they don't have trouble getting moving. They also have inline steering with little to no front caster. The TC cars are also mid motor with inline steering and a counter rotating motor. Admittedly these are 4wd but the point is clear. The aggressive cars on smooth surfaces all have similar design elements. For off-road we just need to add the ability to land jumps. I run MM3 which is counter rotating to the wheels, inline steering, and only 15 front caster which is still more than onroad cars. I run a low ride height but have enough pack and spring rate to land jumps. Why would any of that be hard to drive and unpredictable?
Old 09-10-2014, 08:49 PM   #15025
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Hey Fred, do you mean you have zero rear toe, or just no added toe in the hubs? What suspension blocks are you using? are you back to running an HRC setup since you probably don't need the additional traction of LRC on carpet? I would think most carpet would have a great deal more traction than dirt? Perhaps the indoor clay is close though as we sometimes run slicks. What are your thoughts? and thanks as always!
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 09-10-2014, 10:39 PM   #15026
I'm running 1.5 rear toe per side with 0 rear kick. HRC blocks. Still playing with springs, pistons, oil, and camber link locations. Shorty battery length wise all the way back.
Old 09-11-2014, 01:02 AM   #15027
Hello fredswain,
Thx for the answer!
I also like to run my 210v1 in MM3, if possible at all surfaces?
Actually, at the moment i'm in the planning phase of my own cf chassis, it will look like the infinitiy chassis for the b5m, from xfactory.
What im strugeling now is, to make a bend for the front kick up, maybe with some skid plates, or to make a seperate "bolt on" front piece out of aluminum.
I've some good ideas, for some extra tuning for this type of chassis!
We will see, how it works out....;o)
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 09-11-2014, 08:41 AM   #15028
Sorry dude only asking a question!!! Surely if its faster all the pros would be doing its just my thoughts, i also can think for myself and setup a car but usually if your stuck you can have a look at their setups for a similar track as it wont be far away! Im from the UK and race on Carpet/Astro all the time, I run MM4 i rarely have to make to many setup changes, just some tracks may be more on power or more off power etc etc and need a slightly different setup, i then did the oOple invernational on dirt, apart from changing to rear motor, not much else changed on my setup!
Old 09-11-2014, 09:00 AM   #15029
I wasn't trying to be offensive in my response. I really hate the logic that if someone else does something that it must be for a good reason. That is a terrible assumption. The reality is that in any aspect of engineering (my job), copying is quite common while true innovation is quite rare. Thomas Andrews had a reason for designing the water tight bulkheads of the Titanic so that they only went up to E deck instead of A deck. There was a reason why he didn't use a larger more effective rudder. There was a reason why Captain Smith, the most experienced captain, ignored ice warnings and set a faster pace. There was a reason why Moron Thiokol engineers chose the o-ring material that they did for the Space Shuttle rocket boosters used on every launch up until the Challenger disaster. I could go on and on with examples of how the experts in their field did things that didn't always work out. Up until those events, why would anyone question them? Admittedly we are just talking about rc cars and tuning them but the point to be made is that you should never arbitrarily copy others if you believe you've got a way that works better. Incidentally rc cars today are essentially copies of each other. Look at competing designs over the past 25 years and you'll see similarities from brand to brand with parallel development of features over time. Most things are copies with the occasional new innovation added into the mix. That's essentially what I already said about engineering design.
My number one question to the people that think my techniques are weird is "have you tried it?". The answer is almost always no. Incidentally, those above that agree with me have tried it! It's not to say that it's the only way that it should be done. It is however proof that you don't have to do what others do to get good results. The quote in my signature sums up pretty well how I feel about things.
Old 09-11-2014, 05:43 PM   #15030
LoudOne's Avatar
Trader Rating: 31 (100%+)
Hey folks, just wondering what you're setting your front and rear camber at? Also, what is a good toe setting for the front? Thanks! Bruce
I have the version 1 buggy.
LoudOne is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 Today 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
