Like Tree26Likes
Old 09-02-2014, 05:40 PM   #15001
fq06's Avatar
The chassis holes are different, get the $35 v2 chassis to run the v2 side pods. The rest of the holes are the same.
Originally Posted by 13Maschine View Post
I DON"T HAVE OCD!!!!! :P HAHHAHA
HaHa! I know different
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 09-02-2014, 07:11 PM   #15002
Pittster's Avatar
Default Dex210 Motor cooling fan
So I didn't see info on how to mount a cooling fan.
So using a longer counter sunk screw for lower shock tower mount and the excess thread on the other side holds onto a 25mm fan.
Have not raced yet with it so it might die quickly from a rock but it clear's the shocks and body etc I also added a wind deflector to streamline the air.
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 09-02-2014, 07:30 PM   #15003
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
I'd actually retired my DEX210 in favour of the new Serpent and only pulled it out of retirement to race on a new carpet track that has recently opened here. I'm going to stick with the shorter v1 chassis because the track is pretty tight.
Nice cooling set up Pittster, reminds me of the Brabham F1 'fan car'
AJ
Associated SC5M, Hot Bodies D413, Durango DEX210, Durango DEX410, Mugen Seiki MBX7R
ajj is offline   Reply With Quote
Old 09-03-2014, 01:19 AM   #15004
Originally Posted by ajj View Post
This is the original V2 cab forward body on my V1. Few millimetres between the body and the chassis, I was thinking about getting the V2 side pods to eliminate the gap. Not sure if they'll fit the V1 chassis though.
Hi ajj,
The v2 side pots will not fit, because the v2 chassis is 8mm longer, than the v1.
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 09-03-2014, 02:17 AM   #15005
To all those using a carbon rear tower do you space it out 1mm from the gearbox?
thefan is offline   Reply With Quote
Old 09-03-2014, 03:08 AM   #15006
ekt
ekt's Avatar
I did on my v1, didn't want to risk it possibly flexing into the motor plate.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 09-05-2014, 02:56 PM   #15007
TTim's Avatar
Hi all just building a v2 as mid mount and was just wondering was is better....4 gear or 3 gear ?
cheers
Team Durango DEX210v2
Member of Keorca
TTim is offline   Reply With Quote
Old 09-06-2014, 08:29 AM   #15008
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Hi TTim: 3 gear and 4 gear both have there place depending on what you want to achieve. Personally I prefer 4 gear most of the time but this is mostly due to the tracks I usually run on. I run at OCRC and SCVRC here in Southern California and the surface is a nice high grip clay indoors. So traction is pretty consistent. As with anything it's best to try it to see how it feels to you and notice how it makes the car different.
A couple of very general notes about the differences in handling:
MM4: The car will respond to throttle and braking much more than with a 3 gear setup. This is due to the rotation of the wheels and transmission and there relationship in terms of direction. The car will transfer weight to the rear on throttle and on braking transfer weight to the front.
MM3: The car tends to drive flatter and respond much less to throttle and braking. Same reasoning here. The direction of torque on the motor versus the wheels and transmission, these are the two largest inertial bodies interacting with the car.
I've found this to be very helpful, especially the diagrams.
http://www.team-durango.com/blog/201...onfigurations/
I've found an easy way to see and understand this is to hold the car ready to run and give it throttle and brake and see how the car wants to nose up on throttle and nose down again when you hit the brakes. Switching to MM3 will lessen this effect. Hope that helps!
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 09-07-2014, 01:45 PM   #15009
TTim's Avatar
Thanks 13Maschine.
Member of Keorca
Old 09-07-2014, 04:19 PM   #15010
13Maschine's Avatar
Definitely, I'm sure some of the other guys here will jump in a bit eventually too. Tell us about the track that you run on and how you make out, I'll do my best to help you get dialed!
Old 09-07-2014, 05:43 PM   #15011
Devin's Avatar
TTim,
The website Durango Fansite is a great resource. If you go to tips it brings up several durango blogs that aid in assembly.
Devin is offline   Reply With Quote
Old 09-08-2014, 12:40 PM   #15012
TTim's Avatar
ok thanks everyone for your help.
Member of Keorca
Old 09-08-2014, 02:54 PM   #15013
13Maschine's Avatar
Has anyone run the Exotek Graphite chassis? Comments, love it, hate it etc. Thanks!
Dave
Old 09-08-2014, 03:00 PM   #15014
rcjunky1's Avatar
it looks pretty
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 09-09-2014, 03:55 PM   #15015
You want 4 gear for mid motor!
Team Durango - DNX8 - DEX8 - DEX410v4 - DEX210v2 - Alpha Lutz WE - VP PRO - Futaba - Hudy - Orion
av4625 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16570 09-23-2017 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
