Like Tree26Likes
Old 07-29-2011, 12:12 PM   #136
Trader Rating: 19 (100%+)
Originally Posted by Jmuck69 View Post
I like it! I can see if they were a little upset when the 22 was launched. many comparisons can be had. I don't understand the left side spur gear in the rear motor layout and the weird layout of the slipper adjustment. Overall I like it.
Edit: It looks like you can run the motor left or right in the rear motor configuration. Also, they have the bearings in the front wheels and not in the hubs. a little disappointed in that.
I prefer bearings in the front wheels- less slop. I converted my sc10 to the protrac setup and tried all kinds of things to get the slop out, but in the end I switched back to the original wheels. It seems that the best way to reduce slop and unsprung weight is this way.
Consider that buggy bought once they hit the stores, looks very nice!
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 07-29-2011, 12:29 PM   #137
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
the body looks like a Formula 1 car...
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 07-29-2011, 12:45 PM   #138
TAMAK's Avatar
Trader Rating: 28 (100%+)
Does not resemble the Ifmar car with some key components.: Arms, carbon shocktowers, Carbon chassis. Alum braces.
When will the Production car start hitting the races?
TAMAK is offline   Reply With Quote
Old 07-29-2011, 12:47 PM   #139
teeforb's Avatar
is the gear diff the preferable option? And would it be the same diff as the dex410 series?
thx
Originally Posted by gregm View Post
http://www.team-durango.com/blog/?p=3929
The next generation of 2WD is here – the Team Durango DEX210. We released a teaser but now we’d like to announce a few details and show some more detailed photos.
- 3 or 4 gear configuration in both rear and mid layouts – with the same gearbox*.
· Aluminium Chassis plate with moulded composite side plates
· Moulded composite shock towers
· Big Bore shocks
· Aluminium FF and RR suspension blocks
· Accepts stick or saddle pack battery in both mid and rear motor configurations
· One body for both mid and rear configurations
· Front end – Adjustable wheelbase, axle trail, caster, camber, toe angle in the kit
· Rear end – Adjustable wheelbase, hub toe angle, camber in the kit
· Dual pad slipper clutch
· Droop screws front and rear
· Captured CVD pins and over-size hub bearings
· Ball Diff as standard. Gear diff will be available as an option
Old 07-29-2011, 01:03 PM   #140
Matt Howard's Avatar
anyone wanna buy a TRF201? gotta make room for this bad boy
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 07-29-2011, 01:17 PM   #141
Jmuck69's Avatar
I am AE fan, but this one will occupy my pit space.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 07-29-2011, 01:19 PM   #142
Jmuck69's Avatar
thx
I think the ball diff would be the preferred choice. Gear diffs seem to work better in 4wd where you have both front and rear counteracting and balancing each other. 2WD seems to "diff out". I just don't understand the slipper adjustment sticking out the opposite side like a Schumacher.
B6D | B64D
Old 07-29-2011, 01:31 PM   #143
I know at my local track, gear diffs are the diff of choice for a number of reasons. The big ones are simplicity (fill it with oil and it's ready to go, should feel near the same for a long period until the oil breaks down... ball diff if the screw backs out a bit, you get loose) and ability to hold a load. We had a few guys with "barking" ball diffs. Especially with lower motors, the diff will act correctly for the action, but it's too loose to keep the high torque BL motors from causing them to slip, galling the pads.
AMorgan is offline   Reply With Quote
Old 07-29-2011, 02:02 PM   #144
Little bit concerned about the street price. i am in need of a new buggy but i might wait to see what the verdict is on the performance to the avg racer.
sjenkins97 is offline   Reply With Quote
Old 07-29-2011, 04:58 PM   #145
They are available for preorder at amainhobbies.com street price of $275
Jim Misavage
Tamiya usa, TRF, SpeedZone Batteries, HB Tires, Diff Doctor, Austintown Hobby Race Team
Poptartninja is offline   Reply With Quote
Old 07-29-2011, 05:01 PM   #146
aloksatoor's Avatar
Trader Rating: 42 (100%+)
That is cheap for a rango... but then it does not have the cf options. Will wait for those i guess.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 07-29-2011, 05:01 PM   #147
FastPete's Avatar
Trader Rating: 44 (100%+)
Wow well I will be adding this to my collection very nice
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / Raceform Jigs/ Proamps Servos-Lipos www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 07-29-2011, 05:54 PM   #148
not bad, Durango's aren't known for being cheap, but that's not a bad price IMO
RCTech #361
Old 07-29-2011, 06:18 PM   #149
veecee's Avatar
Trader Rating: 34 (100%+)
I agree it would be good to see some results with this car. I can understand the team guys wanting to race the prototypes at the worlds because it was a car they knew.
The whole point of a 3/4 gear gearbox is that you can get correct motor rotation to properly control the flight of the car. So it's kind of weird they took photos of the car with the motor on the "wrong" side for a rear motor car...
SMOKEM --- XPRESS --- HIRO SEIKO
veecee is offline   Reply With Quote
Old 07-29-2011, 06:26 PM   #150
FastPete's Avatar
How about a ETA Durango?
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Lloyd16
