Xray 808 E-Conversion Kit?
#34
Proline does not have much clearance for batteries. 808 stocker is my fav but still not perfect. You can shim up the front mount which helps a bunch. The BEST body for E808 is the Jconcepts body. Which is too bad because I also think it is the ugliest.
#36
yes it will work. Like I said if it is close than a small shim under the front mount will help. But it definitley has the most room.
#38
#40
2010 Spec
http://www.teamxray.com/teamxray/pro...ria=0&catName=
2009 Spec
http://www.teamxray.com/teamxray/pro...e=XRAY%20XB808
original 808
#41
hello all ran my 808 e today and was wondering what i setup is a good starting point Im currently running ryan lopez from xray set-ups.. one other thing do u use the droop screws running full on the frt seems a bit much to me? ..running indoor clay tight... 5's 1900kv @ 70% or so..
#42
#43
1900 is a handfull on 5s. I run that motor on 4s and its tons of power! Dont think I could control it on 4s.
