WILL LI-PO'S BE OK WITH NO USE FOR 3-4 MONTHS???
I got two li-po's one's a 11.1v and the other is a 7.4v both are losi packs and i havent used them for at least 2 months and it looks like it will be another 1-2 more months due to a delay from x-mas cost in my rebuild project so my question is will i have any problems when i do use then again or should i try to have a friend do a few cycles on them every now and then with his car to keep them sane?.
Thanks,
Nate
Thanks,
Nate
id suggest to have ur friend put cycles through em once in a while but im also intrested in knowing the exact answer to this question, i have a trex 500 heli with 6s batteries and fly it like 1ce evry couple months...
I would prefer to have them cycled a few times, but many people have stored them for months on end with no problems. Just make sure they are stored at appx. 3.8V per cell.
check your charger...
my hyperion has a STORE mode for lipos...
I would check them about one a month and as long as voltage is basically not changing, they're fine. If you see voltage start to change, then they need immed attention - charge them and then discharge them. Note that SMC recommends a once a month cycle for their lipos to prevent capacity loss due to inactivity.
Mine have been sitting for over 5 months now. I havn't even thought about them. They are 2500 miles away from me now. When I go home for christmas I will have to charge them.
I bought this one (haven't got it yet...)
http://hobbycity.com/hobbycity/store...er_3_in_1_2-6S
Will do a little more, but costs a little more too.
just cycle them a few times once and a while then put them away at %60 after cycling and you should be good to go
I think i'm just going to let my buddy run them a few times and then store them at 60% like most people said and i have great planes triton eq charger but i don't know if it gots a store mode for li-po's so i will check that first.
thanks everyone for the helpful replies!
