Kyosho Inferno VE vs. OFNA LX-1
#16
Some more
#18
I did modify the tray slightly, but not by much.
#19
Wow, those O'Donnell shocks really dwarf the stock Inferno shocks! I have a set of TTR ST-1 shocks I can use that have been very durable on my truggy. I'm really wanting to get an Inferno VE. I can get a pretty good price on one. But finances have me holding back. That and I'm interested in a 4WD HPI Blitz too, but I don't know when (if ever) that will come out. I was told by someone that knows people in the industry that HPI has no current plans for a 4WD Blitz.
#20
Even the stock model looks awesome. 4WD, VXL system, 2.4Ghz radio, plus it is has a much lower center of balance compared to the 2WD model. It should be an awesome truck, and running 3S lipo should keep up with 1/8 scale buggies...
I will have the Inferno VE at the track tomorrow and I will report back on how the O'Donnell shocks performed.
#21
I emailed Kyosho USA tech support about the Vortex ESC stock settings and this was their response (same day),
"The speed control is not adjustable as it sits, it is a plug and play. There is an optional setting box where you will be able to adjust quite a few parameters on the speed control. ( the setting box should become available in about a month)
This is what I could find out about the stock settings:
Battery is auto detect
Brake is 10% (power, not drag)
Acceleration curve MED
Forward power limit 100% (Full power)
Reverse 50% power
Drive frequency 8khz
That’s the best I can do for now. I will try to gather more information as it becomes available.
Best Regards,
Derek Furutani
Kyosho Corporation of America"
#22
I'm not a big fan of the way the Slash looks. One of the main reasons I like an SC is it's looks and realism and I just don't really like the way the Slash looks, at least the 2WD. I really like the way the Blitz looks though. I've seen the Slash, Blitz, and SC10 in person. I don't think my LHS will have an Ofna Hyper SC on display as Ofna's not one of their main brands (though they can get them). The Hyper does look quite nice though.
I wonder if the program box will be similar, if not identical, to the Hobbywing program boxes since HW makes Orion ESCs. If that's the case, I have a few program boxes already. I hope you can adjust the LVC as I don't like the typical default setting of 3.0V. That lets one cell drop too low if others are a bit higher. The LVC and the brakes would be a couple of things I'd adjust, but otherwise the stock settings look pretty good.
I checked the top speed with the stock gearing (I forgot how many teeth are on the spur, but I used the right amount when I did the calculation) and the stock 12T pinion and it only showed a top speed of about 30mph. I gear most of my vehicles for about 40mph. Can anyone comment on what they think the top speed is? Just wondering if the calculations are right.
#23
#24
I used the parts listed on the parts list:
12T pinion
48T spur
4s LiPo
2050kV motor
4.5" Tire OD
Top speed = 30.7mph
Here's with various pinions:
12T 30.70 mph
13T 33.26 mph
14T 35.82 mph
15T 38.37 mph
16T 40.93 mph
17T 43.49 mph
18T 46.05 mph
19T 48.61 mph
20T 51.17 mph
12T pinion
48T spur
4s LiPo
2050kV motor
4.5" Tire OD
Top speed = 30.7mph
12T 30.70 mph
13T 33.26 mph
14T 35.82 mph
15T 38.37 mph
16T 40.93 mph
17T 43.49 mph
18T 46.05 mph
19T 48.61 mph
20T 51.17 mph
#25
I thought this thing had a 54T spur?
#27
More spur teeth would result in lower top speed. For more speed, you need a taller gear ratio (lower number).
#29
Get the Kyosho, better quality the the Ofna. Ive owned the inferno series since day one. The VE is based on the 7.5 inferno which has been a world champion buggy a few years back. Parts up to the Kyosho MP 777 will fit for the most part on the VE, including Kyosho big bore shocks. The ofna chassis is the base model of their buggy line.
#30
It's probably cheaper to pick up a multi-pack of Novak or RRP pinions to adjust top speed to your needs. I've gotten the Novak 3-pack pinions from Tower before...nice deal and the Novak pinions so far have been as durable as the RRPs.
