RC8 Steering Block Bushing Problem Fix
Does anyone know how to stop these from backing out. Yes I use blue locktite and check them after a run or two, but I know im not the only one that looses these. If you got a fix that has worked please let me know.
Nothing?
I have never had this problem even without locktight. Biggest thing is to make sure they are install properly. The tops are different from the bottoms. They are keyed also.
I have a friend at the track that has no issues either.... but I have three more that do have this problem? Maybe its just worn steering blocks? Guess I will pull it apart and see....
I've had this problem, but haven't found a solution. I use locktite and make sure they are seated right before tightening and I still lose them once in a awhile. Worst thing is that the replacement parts aren't cheap.
Yeah its about ten bucks a pop if you loose the shim....
So far, so good, here. I bought the car used, and don't know how the guy put those in, but they're staying put. He was aware of the problem, and even included a spare set.
