I was just utside in the darm drivimg my rustler in pur dark, judging by sound, withonly a little light from the garage.well i turned to muc ad hit te 4-wheee full see an broke both caster blocks. So don wana screw witht again o im gana get front rpm caster blocks. its like 7 bucks at thebarn floor, but theres a pin i bent severy tht goes rightthru it that holds the bearing holder? is it called that? well i need a new one of the pins mabey 2 and i see that the caster blocks dont come with it. were can i get it?
I would love to help you out, but I'm having problem to understand your post. Not trying to be difficult but "muc ad hit te 4-wheee" really confused me. I'm guessing you broke your caster block from the title, what are you asking?
my computer was being dumb and slow and not puting all th letters. but yea i was drivng in the dark wit some light and hit the 4-wheeler full speed. broke both caster blocks, and bent one of the pins that hold the bearing holder thig. which dosent come with the caster blocks, so where do i get the pins?
can' undtned how you wht he was talking about thre pretty amazing mouses on the barn flr.
8ight-E 2.0 - XP DS1015 - Mamba Monster 1/8 ESC, 2200kv
Stampede VXL - my pocket rocket
you're = you are / your = of or relating to one or oneself
there = That car is over there / their = I suspect their car is quicker
Get rpm parts. Aluminum is expensive and instead of breaking, it bends. Stock plastic is even stronger than aluminum. RPM is just a stronger plastic that will last much longer. http://www3.towerhobbies.com/cgi-bin...&I=LXRRR2&P=BR
BIG BLOCK TRAXXAS SLAYER FOR SALE
ok ill get rpm, but where do i get the pin that holds the bearig holder
You will keep bending pins if you get the RPM. The aluminum caster blocks are a MUST. The RPM stuf is good, but will flex instead of break most of the time. You don't want any flexing in the caster block because it will bend your pins. I bent a bunch with RPM before getting the STRC caster blocks.
just go with the traxxas alluminum I got them and well have never had a problem so my advise is go alluminum because rpm is great just casters are one of those things you don't want flex
hm im confused rpm or alluminum? snow board said rpm, others said alluminum. so which and i still need to find pins. whats the difference between rpm and alluminum?
