Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-30-2009, 06:27 PM   #31
If you are still not certain, go to traxxas forum then you will find NO ONE will suggest to use RPM caster block, only aluminum ones.
E-maxx 16.8 - 775, ULX1 shocks
Rustler VXl - wide
MREV VXL - HS85mg, hopper bar, Tactic 2.4
Slash VXL - REM tranny, 17/58 32p, Tactic 2.4
lowtec is offline   Reply With Quote
Old 10-30-2009, 06:44 PM   #32
well i am getting rpm, but i asked which kingpins are stronger then stock?
forest_parker is offline   Reply With Quote
Old 10-30-2009, 06:48 PM   #33
the thing is, RPM will bend king pin in a mild crash, while the alloy won't. I have never bend a king pin ever since I changed to alloy caster block, as many others
Rustler VXl - wide
Old 10-30-2009, 07:00 PM   #34
oh well, ithink i an avoid tha f there i such thing as a stronger kigpin?
Old 10-30-2009, 07:21 PM   #35
well i found some relly cheap allumium parts, so i would like to know what is better rpm or aluminum. because rpm "never breaks but bends kingpins" alluminum "bends but dont bend kingpis"
Old 10-30-2009, 07:24 PM   #36
I have never seen a bent alloy caster block, if it does bend, i don't thing anything attached to it would survive, that's the least of your concern
Rustler VXl - wide
Old 10-30-2009, 07:26 PM   #37
ok but i want more then 1 opinion on this
Old 10-30-2009, 07:53 PM   #38
don't listen to me, go to Traxxas rustler forum, search (caster block) you can find 100 of threads about them. I can guarantee you 99.9% of them would suggest AGAINST RPM blocks.
Rustler VXl - wide
Old 10-30-2009, 09:18 PM   #39
Trader Rating: 40 (100%+)
You asked this question 3 times after I posted.
Originally Posted by forest_parker View Post
hm, well what kind of king pins will never brake on my rustler
Did you read this post?
Originally Posted by ta_man View Post
There is a far better solution but it requires a modicum of skill to execute properly.
Drill/ream the kingpin holes in the caster block and steering block to 1/8". Then take some extra 1/8" screw pins like used for the A-Arms and cut them to the proper length to be used as a new kingpin screwed in from the bottom of the caster block. I've been racing a Rustler for 8 years now - I bent one of those thin kingpins within a few races. Then I did this mod and have run the remaing 7.5 years on the same pair of kingpins. That is with stock Traxxas plastic caster blocks and RPM steering blocks.
BTW, the only reason I used a Traxxas screw pin for the king pin is that it is a Spec class where we could not use any non-traxxas parts (with limited exceptions - like the bearing carriers). A better solution would be to find a standard 1/8th hinge pin from some other car and use that as a kingpin. But I had to use a Traxxas part for my Spec race truck.
A traxxas 1/8th screw pin used as a kingpin is way stronger the standard ones. About 2.6 times the material and probably 2.6 times the strength.
If you want something even stronger find a 1/8" Titanium hinge pin from another car and use that as a kingpin. You will have to look around and either take some measurements or check parts at a LHS to see what fits. Of couse, this means you will actually have to do some work to figure this out and install it, instead of someone else doing it for you.
ta_man is offline   Reply With Quote
Old 10-30-2009, 10:24 PM   #40
Vdub517's Avatar
Dont Wreck! HAHAHA nah i used RPM's if your looking at RACING RPM's lifetime warranty for one lighter in weight for two and hell of alot cheaper!!! BACKYARD BASHING i would go aluminum at that point it doesnt matter your out to have fun and smash things up in the end anyhow so...in the end to each his own YOU buy what YOU can afford and whatever YOU like...Hope all works for you!!
Vdub517 is offline   Reply With Quote
Old 10-31-2009, 07:06 AM   #41
nice to say when the lhs is four hurs away, if it were an hour or closer, i wouldent even be on this forum, well, i am gana call some hoby stores in the state and neighboring states so they will actually give me a real anwser to all o my qustions and i wont have to bug u guys
Old 11-02-2009, 02:10 PM   #42
well im gtting alluminum, like tey say, a hit that will bend alluminum, will still break rpm, and alluminum ca bend back, plus theres less kingpin breaks
Old 11-02-2009, 03:57 PM   #43
Once you learn to drive and stop hitting things you will wonder why you spent all this time and effort trying to make the car indestructible. That's what happened to me.
Old 11-02-2009, 04:16 PM   #44
true, but that is also a part that breaks alot i heard, might as well stop the problem in the tracks, and even the best still crash once in a while
Old 11-03-2009, 01:50 PM   #45
sLaSh It UPP's Avatar
yeah practice makes perfect
MiNi-Tx2// MiNi-LsTx2//sLaSh//RuStY vXl//E-rEvo//CaStLe CrEaTiOnS//TrAxXaS//MaX AmPss
sLaSh It UPP is offline   Reply With Quote
Forum Jump
Roller Rustler TONS of Extras Vdub517 R/C Items: For Sale/Trade 21 10-16-2009 10:08 PM
Rustler VXL. help fixing steering block Roosty Electric Off-Road 10 07-26-2009 01:21 AM
F/S Bunch of New in Pack Team Associated Parts, and Pinions. Need them gone!! NitroMaxx3.3 R/C Items: For Sale/Trade 7 12-23-2007 06:49 AM
rustler vxl jbinny Rookie Zone 48 12-14-2007 10:21 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
