Hot Battery
Hot Battery
Is it good to charge or ride your battery when it is hot?
Yea... We need more idfo is it a lipo if so if it is warm u can charge it if it's a cad or mah I wait till there cool. That's just how I do it.
Yea hot and lipo is bad. But mine are slightly warm after 30 min. That's normal.
its an nimh battery,and itgets really hot
Thats ok, NiMh just do that. Its part of teh chemical reaction that generates the current.
Your NiMH pac shouldn't be getting so hot you see/hear cells venting though. Venting is when cell gets so hot it vents some of the internal media out of a weak spot in the cell casing. A vented cell is pretty much done and has to be replaced otherwise it drags the pac down.
You should let a nimh cool off good before charging. Ideally for a couple of hours at least. It’s normal to get warm at the end of charging, and during running. But if you don’t let it cool off before recharging I’m pretty sure you will lose performance, increased internal resistance, and lose run time/capacity.
You can recharge quicker than that, but it's not ideal.
