Bought my new toy!
Bought my new toy!
Bought me a Sc10 and should be here in the middle of the week. Looking for some suggestions on a BRUSHED motor to run in it. I will be going brushless eventually maybe after christmas. So please shout out some good motors that would Do great in the truck. I am not racing it just having fun. Thanks
If you have an ESC already with low-turn capability, something like a Team Checkpoint 10T two-wire brushed (10x2). Not too low a turn, and yet tons of fun in 1/10 scale. Otherwise, for just playing around, there are a lot of 19T brushed motors out there.
The Stock XP SC200 is apparently a 17T or higher ESC. So, 19T brushed would be about right. The lower turn you go, the faster you would use up your batteries (ie. higher wattage motors mean lower runtime)
If you use anything faster than a 19t brushed motor you will burn out your esc.
The stock motor is more than likely already faster than any of the ones that you have pictured. Though its considered slow, its still faster than stock turn motors, especially older ones.
If you are looking for a good, faster motor, that will work with your esc, that is not expensive, buy a 19t komodo dragon, for around $30. Yes there are others more expensive, cheaper, faster, better ect....... Buy if your going BL after christmas, why waste your money on somethig more expensive, and or risk having to buy another esc right away.
My .02 is keep your stock motor in there, dont put any money into it at all, and use that $30 towards the price of your BL system.
If you want to improve your sc10, there are two things you can do right away. First it to put some black grease in the sealed rear diff, so your not spinning one wheel on a regular basis, and second is change those terrible stock tires.
Good luck
Good luck
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 42 (100%+)
yourr kinda putting the cart before the horse.The stock sc10 tires are squirley with the stock 17turn out of the box.I think before I went and put more power in the truck I would look into getting some goosebumps,or bowtie SC tires at least for the rear end of the truck.
