i have my brace mounted in the same spot as you guys do. i might have o get one of those axial battery trays
They are cheap, and secure the battery well. It also helps support a soft case battery on the bottom as we all know the bottom of the chassis is not flat.
I also made a rear body mount using the other trans top hole and some threaded rod (cut head off a bolt). I then threaded in a body mount from a 1/10th Losi Late Model. My car is in my trunk or I would take a photo.......
Mid-Motor Speed-T,Mid-Motor xxx-cr, 2 Slash's, XXX-S, Mini-T, JRX Pro (still runs!)
Hot Bodies Ve8
back from the track...not too bad. i had to re-learn how to drive though. also have a lot of tuning to do, lol. i could not find and tire that would give good sidways traction. only time will tell if i will keep it. any setup tips?
for better on power steering i run 1 gold washer on the rear hub carrier and 2 of those washers on the front inner camber link location. ya know that spacer thats on the inside of the spindle carrier thats on the screw that screws into the axle? i run that spacer on the outide of the spindle carrier. that helps with steering too.
Pretty much. I would have guessed it should have cracked at my mounting points, but it was a Z across the center of the Pivot plate. Just a bad hard landing.
Hot Bodies Ve8
mopar1994 what did you use to make your standups for the 4 gear tranny? I am reworking my mid motor rc10gt putting a 4 gear in it and would like to make more mounts at different heights for adjustments.
whats a really good, fast brushless motor that i could get? i just saw some team ptityo motors and they look like they perform really good. does team ptityo just modify one of your motors or can you just buy a motor from them?
