soldering 12gwg to 14 gwg
Shouldn't be too much of an issue either way but it's safer to go with a thicker wire then factory recommends instead of thinner.
Neither is a fantastic idea though so if you can scrounge up some more of one or the other you should prob do it all in one piece.
Plus that's just one more joint which can be a potential weak spot and adds a tiny bit more resistance.
EDIT - He apparently types faster than me. Both put down at 10:17.
One would think we could have more exciting lives then going to an R/C forum on a Friday night. Kinda sad. LOL
No, no, I wasn't implying to use 30AWG wires, just trying to make people realize how much current they can carry before they pop.
I'd safely bet they can carry about 5 to 10A before they pop...
Just look at pop fuses... Fuses are basically designed to have the most minimal amount of conductor its rated current... Once you get to that rated current or over, it pops...
12AWG are awesome though. Especially multistranded. Dean's wet noodles uses over 3000 strands of copper to make a 12AWG stranded wire... Wet noodles from Deans are probably the best wire out there. It can handle a ton of current and flex like a noodle...
I too love Deans anything. Wire, plugs, ...... guess that's it. But those two things are great.
Wanna side bet on how much voltage drop you will have just before poping? Or how much heat is generated?
There is more to proper wiring than just survivability of the wire.
Super Moderator
Trader Rating: 31 (100%+)
Don't touch the wire as it starts to glow either, would hate see anyone get hurt
