Mamba Monster problem
Its time to call Castle before you eliminate any hopes for any warranty coverage you may have had.
http://www.castlecreations.com/support/contact.html
I have called Castle now and I am waiting for an answer.
You may need to update the software. I bought an SC8 from a guy with a MMM 2200 system. He drove it in front of me and worked perfect. I get it home and go to drive and the same yellow flashing light you speak of. Nothing would work or calibrate.
I updated the software and it works perfect to this day 3 months later.
Hi
I tried the new software but without succes.
The code for teh flashing light says "possible problem with controller" so it looks like its something that CC is going to have to fix. The meanings of the leds are located here -
http://rc-monster.com/forum/showthread.php?t=20020
Hi
problem is solved.
The ESC works.
problem is solved.
The ESC works.
I am an idiot.
The wires from the ESC to the receiver were not in the right order.
But I have had some real bonehead problems too that were the result of user error so I'm not at all judging! Glad it got worked out before sending it back to Castle. THEY might have judged.
