Kyosho Ultima SC
#1501
Swept qualifiers and the A-Main in stock class yet again. Just for fun, I also raced open class with my stock USC and placed 4th in the A.
I was again accused of cheating.. sort of. One of the top 3 drivers at our track asked me if my truck was 4WD and I said "nope". He actually flipped my USC upside down with his foot so he could see the underside of it and said "sure handles like it's 4wd". hahahaha I think he was a little bent that my USC outmaneuvers his SC10.
#1502
The bones seemed allright,my fault haven't had a dogbone car since 89,the gear diff was fine,it was the top shaft.When I put the ball diff in and tried the truck,too late,the dbone was toast.the stock shocks haven't leaked yet,perhaps that washer that holds the spacers and orings nedds to be seated a little more,isn't it held in by friction?
#1503
New USC SP2, mid motor, the finance dep is ASKINNNNG!
#1504
What's a good pinion/spur to go with a Castle 4600Kv motor?
the 19/82 that's in there right now seems like it's somewhat high geared but I wouldn't call the acceleration I'm getting to be sluggish at all, it usually breaks traction on the stock tires on any surface.
#1505
Anyone have problems with the stock gear diff locking up or slipping? My gear diff started to make some noise and when I took it apart, there were alot of metal flakes in the grease.
#1507
slipping after about 20 minutes of run after purchase, I think it is a silver colored grease in the diff, mine barely had any left, I cleaned it out, shimmed behind the large gears (one thin shim each) and refilled with grease and it has been ran another 40 minutes and the diff looks great inside and feels good on the track
#1510
after installing a new top shaft, i was adjusting my slipper clutch and my damn speed conrtoll burnt up. Thanks to joe pillars had another one which also burnt up when he did it. So what is a good speed controller? Was thinking about goin brushless 17.5 too. So any thoughts would be awesome
#1511
#1512
I saw an RB5 SP2 that is or being released
Itīs not that hard to put some "sp" goodies in it and selling it as
a kit
a kit
#1515
Can we convert the RB5 SP2 to the Ultima SC?
