5.5t or 8.5t help??? >
Old 09-14-2009, 07:56 PM
  #16
JSR
Trader Rating: 18 (100%+)
I would get the 8.5T and gear taller for the top speed that you need. The lower kV will provide more low-end torque/grunt and I personally prefer running lower kV motors and gear taller for more speed as they provide enough torque for high top speeds.
For the ESC, I'd go 60A. More headroom and for a 4WD, the 60A is better IMO. I wouldn't use the 35A on anything over a 1/10 on-road. For the minor price difference, the 60A offers more performance margin and flexbility of use.
JSR is offline
Old 09-15-2009, 03:44 AM
  #17
drs92's Avatar
Trader Rating: 45 (100%+)
Does the 8.5 have more low end then 5.5? what would be the gearing on the 8.5?
drs92 is offline
Old 09-15-2009, 09:58 AM
  #18
JSR
Lower kv more generate (or are capable of) more torque. That's why you see big 1/8 MTs and truggies running low kv motors as torque is need for the weight. Higher kv spin faster and consume more curren so they typically run hotter.
Not sur gearing. I have no info on the gear ratios for your buggy. Use rcm's gearing calculator.
JSR is offline
Old 09-15-2009, 10:32 AM
  #19
whitrzac's Avatar
Trader Rating: 97 (100%+)
http://cgi.ebay.com/Ezrun-9T-brushle...d=p3286.c0.m14
whitrzac is offline
Old 09-15-2009, 06:28 PM
  #20
JSR
Don't get the finned-can HW motors! Those are 380-size motors inside a 540-size can (if you remove the size of the fins, it becomes a 380-can). The finned-can motors are all designed with whole numbers (i.e. 9T). These will heat up a lot and quickly powering anything more than a 1/10 on-road. You can run 1/10 2WD with these and they'll be quick, but they will run much hotter than if you ran the .5T motors.
The non-finned HW motors that end in .5T are the ones to get (5.5T, 8.5T, 13.5T, and 17.5T). Those are true 540 motors and work great.
JSR is offline
Old 09-15-2009, 06:41 PM
  #21
mcdogboy's Avatar
I reackon the hobbywing 5.5 is about comparable to a novak 6.5.
Damn nice little motor for the price, and the speedy's nice as well.
mcdogboy is offline
Old 09-15-2009, 06:53 PM
  #22
drs92's Avatar
http://www.amainhobbies.com/product_...r-Combo-4800kV
This?
So the hobby wing 5.5 is like the novak 6.5? Then go with the 5.5 then right?
drs92 is offline
Old 09-15-2009, 06:57 PM
  #23
mcdogboy's Avatar
I've got one, and it's been solid, compared to my friend's 6.5 novak they seem to have about the same power.
Can't argue with the price.
mcdogboy is offline
Old 09-15-2009, 07:01 PM
  #24
glassdoctor's Avatar
I would recommend the 8.5 combo because you would be less likely to have some heat issues vs. the 5.5 in a 4wd. And, 8.5 isn't exactly slow... have you seen what a properly geared 13.5 does in a 2wd? wheelies
If you need a ballistic setup, then go with a known product instead
glassdoctor is offline
Old 09-15-2009, 07:07 PM
  #25
drs92's Avatar
http://www.wnyrcinfo.com/site/module...r=asc&start=10
theres my track! Dont need a ballistic set-up. Mcdogboy says the hobby wing is comparable to the novak 6.5 so im leaning to it. But I had a couple say 8.5t. Ive been doing my research and getting different awnsers.
drs92 is offline
Old 09-15-2009, 07:10 PM
  #26
revo61's Avatar
Trader Rating: 18 (95%+)
The lights I think have less torque. Get the regular 6.5.
Originally Posted by derek_18mt
I think im going to buy the hobbywing esc and buy a remanufactured velociti light or velociti 6.5 and zippy lipos. Does that sound better? Whats the diff. bewteen the velocitis which would be better? And a 35a esc or 60a?
revo61 is offline
