New guy with a new car (8ight-E 2.0)
#46
Definintely get the shock service parts kit. Much cheaper to get it all together rather than purchase seperately. But I would still order more of the shock boots as those wear down easy.
http://www.losipartshouse.com/servle...e-Parts/Detail
#47
I found the shock rebuild kit. I plan on ordering it next week when I order some other goodies like diff lubes and some other staples.
Here is what I went with on this order.
Dynamite 5 Piece Standard Nut Driver Set
Dynamite 5 Piece Standard Hex Driver Set
Team Losi F/R CV Driveshafts (2): 8B
Team Losi Aluminum Servo Saver Arm (2.0)
Team Losi 8IGHT Screw/Nut Assortment Box
Racers Edge Mini Body Clips (10)
Racers Edge Easy Grip Body Clips (10)
Deans Ultra Plug (1 pair)
I also ordered three Turnigy 5000mAh 4S 25C Lipo Packs as well.
#48
The turnigy packs are great. I order 2 more 5s packs 5000 mah for only 50 bucks a pop 2 weeks ago.
Don't know what your mini body clips are for. I am guessing a different car?
#50
Look in the instructions for screw sizes and order them from mcmaster for the price of a losi 8 pack you can get a box of 50. The front right and rear left lower shock screws will unscrew themselves ans the arms move. Lunsford sells some pricy lefthand screws to fix the problem. I replace the button head screws with capheads and drill them for safty wire to keep them in place.
#51
Oh yeah, and don't forget to put some velcro in your battery tray. I use the rough side on the battery and the soft side in the tray. It keeps the battery from slipping around and also keeps the front part of the battery tray from breaking. If your car ends up like mine, you just end up using 2 body clips. One for the radio tray and just one for the front body mounting hole. I actually ended up removing the rear body post and I just have velcro holding the body down in the rear. It's never come loose to this point. I'm with you though, I tend to throw in 99 cent purchases when I order stuff online, whether or not I need it. haha
#52
Thanks for the tips guys, appreciate it.
I'm done spending money for a few days, I promise. Other than ordering a few lipo's for the road car I'm calling it quits!
A Main Hobbies Athletic Gray "Splash" T-Shirt (X-Large) 1 $0.00 $0.00
Team Associated Silicone Differential Fluid (5,000cst) (2oz)
Team Associated Silicone Differential Fluid (7,000cst) (2oz)
Dynamite 5 Piece Screwdriver Set
Hitec HS-645MG High Torque Metal Gear Servo S/JR/Z
Team Losi Shock Service Parts & Box (8ight/8ight-T)
Team Losi Turn Buckle Wrench, 3,4mm
Model Expo Needle Nose Pliers
Model Expo Diagonal Cutters
Pactra Masking Tape (1/16")
Protoform LTC-R Touring Car Clear Body (190mm)
PTK-2000 ProTek R/C 2-Way Automatic Wire Cutter/Stripper
Racers Edge Associated/Losi Ball End Hex Driver Set (5)
RRP4345 Robinson Racing "Aluminum Pro" 64P Pinion Gear (45T)
Trinity Reference 6 Cell Performance Pack w/Tamiya Connector (7.2V/3600mAh)
Deans Female Ultra Plug
Team Losi 1/10 Xcelorin Brushless ESC/Motor Combo (6400kV)
Hot Bodies Cyclone S 1/10th Electric Touring Car Kit (No Body)
