New guy with a new car (8ight-E 2.0)
#31
For the money I believe I will get quite a bit of enjoyment out of this hobby. On top of that it will be a great way to take my mind off of not being able to race road bikes. It should get me out of the funk I have been in since my two knee surgeries earlier this year.
#32
The only thing you forgot is a Lipo sack. They do work and can save you from being homeless. If you are going to race you might want to get a personal transponder also.
#33
PTK-LIPOSAFE ProTek R/C Lithium Polymer Flame Resistant Charging Bag (23x30cm)
I'll check into the transponder but I have to work the next four weekend (family business) so I'm not sure if I will get to race any before next season. I will get one when the time goes though, thank you.
#34
Guest
lowcel you are my idol!! ha-ha talk about a shopping spree!! ha ha well trust me you will be happy when you have it out on a track and your kicking but !!! these buggies are great ! but yes they do hurt the pocket book!! ha ha
#36
Thanks, but isn't that what this is or do I need to get something else??
#37
Sorry I missed the Lipo sack on your list. And I know of 3 people personally that have had lipo fires on the charger when they where not in the same room. And they were not so called cheap lipos either.
#38
Guest
most lipo fires happen when a cell is punctured or if the sell is damaged and you dont have a good charger that can tell you if it. that's my experience and opinion this is not fact so i don't want to hear people jumping on my case but lowcel you will be okay i never had a problem and ive been running 1/8 scale for about a year and half
#39
Now, anyone have any suggestions on spare parts I should pick up? What are some common broken parts on the 8-E 2.0? What pinion gears should I pick up? Anything else you can think of?
I'm starting from scratch and I would hate to drive an hour (each way) to drive the car only to break something common and easy to replace five minutes after I get there.
Thanks again everyone. Also, I promise I'm not wasting everyone's time. I'm listening to all suggestions.
#41
I don't think you will need a arms. At least I haven't had to change any for the past year I have been driving my 8ight. Make sure to get the aluminum servo horn. You will probably strip the plastic ones on your first run. Other than that, I can say I have invested in shock shafts, bottom shock caps, I would also get the shock rebuild kit for the 8ight and some extra boots. Maybe an assortment of pinion gears. I have had a few pinions wear out over time. I actually switched to the Kyosho plastic 46T spur and since then I haven't worn out a pinion. There really isn't much else outside of electronics that you would need.
IMO 8th scale, outside of the initial investment (which is about the same for any scale), 8th scale electric buggy is probably the most cost effective and reliable RC category. I probably spent twice as much on my 10th scale cars than I have on my 8ight. In fact with my 8ight, I spend more on track fees than spare parts!
#42
Thank you. I am putting my order together now. Should I order the aluminum motor heat sink as well?
Here is my shopping cart so far.
Team Losi Body Clips (12)
Team Losi 4mm Rod End Set
Team Losi 8IGHT Screw/Nut Assortment Box
Racers Edge Easy Grip Body Clips (10)
Team Losi F/R CV Driveshafts (2): 8B
Team Losi Aluminum Servo Saver Arm (2.0)
Team Losi 15mm Shock Boot Set (4)
Dynamite 5 Piece Standard Hex Driver Set
Dynamite 5 Piece Standard Nut Driver Set
#45
http://www.losipartshouse.com/servle...e-Parts/Detail
