Old 09-05-2009, 01:46 PM   #1
Questions?? Rebuilding XXXT Gen 1 Tranny
Hit the search feature first before posting this question. Couldn't find specifics on what I need assistance with.
I'm gonna be cracking open my Gen 1 Tranny sometime in the very near future to do a reuild. I'd like to know what parts I need for a complete rebuild (or if I really need to) and where the best place to buy would be. I know for sure I'm going to need the Outdrives since they are pretty well worn from the drive shafts.
Thank you very much in advace for any help you guys can provide!
Losi XXX-T MF1/MF2
Airtronics MX-3
Novak Havoc Brushless (Coming Soon)
thomasjtsi is offline   Reply With Quote
Old 09-05-2009, 03:41 PM   #2
Matt Sunderlage's Avatar
Well if the outdrives are done you probably need a full rebuild.
1. outdrives
2. diff rings
3. difff balls
4. thrust bearing
5. diff screw w/nut and washers
Check the bearings too if gritty your call on replacement. Also look at the idler gear and top shaft. Those parts hold up well they, should be ok.
Just take your time when you rebuild it and you should be good to go!
Matt Sunderlage is offline   Reply With Quote
Old 09-05-2009, 04:17 PM   #3
Trader Rating: 20 (100%+)
xxx123 is offline   Reply With Quote
Old 09-05-2009, 06:19 PM   #4
Davidka's Avatar
Trader Rating: 75 (100%+)
Get the outdrives, diff rings, and screw/spring for the newer "cr" diff, it makes for a smoother, longer lasting diff.
Old 09-05-2009, 08:06 PM   #5
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Send a message via AIM to y2kgtp Send a message via Yahoo to y2kgtp
Get the rings\balls\caged thrust bearing from here....
http://www.bfastrc.com/losi.html
"Yes my car is technically illegal, but still its either just as fast or slower than any other car on the track so whats the issue with it being illegal?"
y2kgtp is offline   Reply With Quote
Old 09-05-2009, 08:31 PM   #6
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
+1
Best set you ever buy .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 09-05-2009, 09:26 PM   #7
So, with ordering the "Pro Driver Kit" from the above site... all I need other than that to do a full rebuild are the outdrives and diff screw w/ nut and washers right? Thanks guys!
Losi XXX-T MF1/MF2
Airtronics MX-3
Old 09-05-2009, 09:32 PM   #8
y2kgtp's Avatar
Pretty much....I just ordered a Pro kit tonight as well.....this thread reminded me I needed one for a xxx-cr I picked up...
Old 09-06-2009, 03:37 AM   #9
B-FAST R/C's Avatar
If you do not have them already, Diff Lube and Thrust Bearing grease too. Also available at Bfastrc,com.
http://www.bfastrc.com/prolube.html
Thanks for the kind words guys!
Fred
www.bfastrc.com *** Feel The Diff!! ***
arcshobbies mcculloughsrcracing
B-FAST R/C is offline   Reply With Quote
Old 09-06-2009, 07:20 AM   #10
Briguy's Avatar
Fred
Your the best and so many people have problems with diffs . The stocks are good but much easier , faster , and smoother with Bfast !
Royal R/C & Hobby
Old 09-06-2009, 07:28 AM   #11
y2kgtp's Avatar
Fred
I have both, and they are great as well....they come in syringes for easy application, and more than you will need for quite some time.
Old 09-06-2009, 03:11 PM   #12
So, with ordering the hardare and lubes from bfastrc.com... where should I get the outdrives and diff screw w/ nut and washers? Any suggestions?
Losi XXX-T MF1/MF2
Airtronics MX-3
Old 09-06-2009, 03:41 PM   #13
y2kgtp's Avatar
I prefer Amain myself for most of my purchases
http://www.amainhobbies.com/product_...ring-Screw-Set
I would not think out-drives need to be replaced.....
or just the diff nuts.....
http://www.amainhobbies.com/product_...al-Nut-Carrier
Old 09-06-2009, 03:46 PM   #14
Briguy's Avatar
I usually buy from Horizon or LPH .
Royal R/C & Hobby
Old 09-07-2009, 01:43 PM   #15
Thanks everybody for all the great info. Didn't think it would cost this much to rebuild... that's for sure. But if I want it done right I'll pay what it takes. Again, thanks everyone!!!
Losi XXX-T MF1/MF2
Airtronics MX-3
losi xxxt ball diff change to a 1/10 desert truck diff newbie2 Electric Off-Road 49 12-13-2010 07:49 PM
