Old 09-07-2009, 08:32 AM   #31
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Ok , I changed .txt to .zip but when I right click on it again I do not get an extract option .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 09-07-2009, 08:36 AM   #32
Did the icon change? It should look like a folder with a little zipper on it. You might just be able to double click on the zip folder then double click on the the exe file.
Just to be sure, your file name went from something like
example.txt
-to-
example.zip
Correct?
Chris
BFast www.BFastrc.com "Feel the Diff"!
NORCAR www.norcarracing.com
Medina R/C Raceway Find us on Facebook!
ccm399 is offline   Reply With Quote
Old 09-07-2009, 08:39 AM   #33
Briguy's Avatar
The icon did not change , still has notepad icon and the file name is TekinHotWire_Beta3_30_RS_V200.zip
Royal R/C & Hobby
Old 09-07-2009, 08:43 AM   #34
Interesting...
That is the file name I have too. What version of operating system are we working with here?
Chris
Old 09-07-2009, 08:45 AM   #35
Briguy's Avatar
Originally Posted by ccm399 View Post
Interesting...
Chris
On my laptop right now with Vista , but it is a 32 bit so should be fine . I will go and try downloading it on my pc with XP and see if it works .
Thanks for the help .
Royal R/C & Hobby
Old 09-07-2009, 08:46 AM   #36
I am heading out the door in a minute here I'll be back later.
A thought would be if you are working with Windows 2000 (or even 98 although I am not sure it will run on 98) you need winzip or some similar software.
Google winzip and download and install it. Then you'll be able to work with zipped files. Note: this does NOT apply to XP or Vista.
I'll check back when I get back home.
Chris
Old 09-07-2009, 09:02 AM   #37
ahh, Vista I think I know what the issue is....
Did the file name actually say TekinHotWire_Beta3_30_RS_V200.txt ? I am guessing it did not. It was probably just TekinHotWire_Beta3_30_RS_V200 as Vista by default hides the extensions of file type.
So here is what we do to fix this...
Click the Windows button (old start button) click control panel > click classic view > click folder options > choose the view tab > then find the radio button (or checkbox) for hide extensions for known file types un-select the option.
Click apply > Click OK then close the control panel.
You file type is probably actually TekinHotWire_Beta3_30_RS_V200.zip.txt So now right click on the file choose rename then back space off the .txt and hit enter. The Icon shold now change to the folder with a zipper then when you right click on it you will get the option to extract all.
Hope this helps!
Chris
Old 09-07-2009, 09:02 AM   #38
Briguy's Avatar
Ok , on both computers I got it to a zip file but when extracting it just brings up the wordpad file and is still named a TXT file .
I already un-selected the hide file extensions option .
Royal R/C & Hobby
Old 09-07-2009, 09:07 AM   #39
How big is the zipped file? Right click on it and choose properties. It should be 5.55 MB. Well, at least that is the side shown on my Vista laptop.
I have it installed and working on mine so I am sure we can get it working on yours!
Chris
Old 09-07-2009, 09:09 AM   #40
Briguy's Avatar
Then there must be something missing because it shows the file is only 4 KB .
Royal R/C & Hobby
Old 09-07-2009, 09:10 AM   #41
Oh,
Another thought!!!!!
When I received it on my home PC (via Outlook express) I had to go into the properties of the file and unblock it to get it to work. I would think Windows mail would behave the same or even more strict then Outlook express.
To unblock the file right click on it and choose properties. Then click the unblock button. Then click ok.
Hopefully that will get you up and running.
Chris
Old 09-07-2009, 09:11 AM   #42
Oh, also if the file was marked as blocked from the first PC it will show blocked on the second one too. Gotta love Microsoft....
Chris
Old 09-07-2009, 10:32 AM   #43
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
You need to watch this how to vid:
+ YouTube Video
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 09-07-2009, 11:21 AM   #44
Well done video Randy!
I will be using that alt shortcut option from now on!!!!
Thanks,
Chris Music
Old 09-07-2009, 11:37 AM   #45
xDaRReLLx87's Avatar
The same thing can be done with WinRAR
Hyper 9E 2000KV T8/RX8- 4S Turnigy 4500 mah
Ko ProPo EX-1 UR 2.4 ghz, Hitec-7950TH
xDaRReLLx87 is offline   Reply With Quote
Ask Team Tekin StephenSobottka Team and Company Discussions 998 10-18-2017 02:44 PM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
TEAM TEKIN RS or R1 ? rcaddict02 Electric On-Road 7 11-16-2008 07:39 PM
Team Tekin RS Brushless Speedo! Randy_Pike Radio and Electronics 21 02-16-2008 12:27 PM
