Finished Assembly of my Hyper 9E
Just finished this afternoon, Happy to report this is a well built buggy and engineering is excellent. I torn it down completely to change diff viscositys to
5K/F-5K/C-3K/R and checked all the hardware. It was all tight and loctite was used everywhere. They did a great job at the factory.
Set up is as follows; NEU 1515-1Y & M.M.M. geared 40/13,weight is 7.5lbs w/4000mah 4s and body,JR DS8711,Spektrum. Anxious to see how it performs with these 17mm bore shocks ?
Very nice....clean build and layout.
I think the center shaft was aluminum. I had it out at some point, didn't feel like steel.
Ahhh. clean virgin buggy. How pretty.
Motor support?
Checking the picture again, I'm curious what that is under the rear of your motor.
I ended up with a motor that doesn't fit the 36mm heatsink / support that's in the kit, was wondering what others were doing.
Is this something you fashioned yourself? I assume it wouldn't be a good idea to rely on the front aluminum mount to hold the weight of the motor without support to the rear.
Next time I have the motor out I'm gonna file off the fins so I can slide the the plastic mount entirely underneath the motor.
Thanks for the compliments fellas,hoping to test and tune Weds.
what is it with hobao? are they out to win ugliest body design? this and the mini st-e are verry ugly bodies...
beutifull paintjob though, very well done
