Old 08-26-2009, 12:04 AM   #1
Armaan's Avatar
Trader Rating: 49 (100%+)
Default Epic Duo2 13.5T vs. Trinity Duo2 13.5T
Any difference between these two motors performance-wise?
http://www3.towerhobbies.com/cgi-bin...?&I=LXTNU7&P=7
http://www3.towerhobbies.com/cgi-bin...&I=LXXYG7&P=ML
Armaan is offline   Reply With Quote
Old 08-26-2009, 12:44 AM   #2
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
The Trinity is the original version of the Duo and the Epic is the new version, the Duo 2.
Performance wise, I cant comment on the Duo 2 (yet) but the original Duo is a rocket! Even geared somewhat aggressively, mine still rarely goes over 150 degrees.
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 08-26-2009, 01:05 AM   #3
hound_dogs_01's Avatar
Trader Rating: 16 (100%+)
Team Epic now owns trinity and trinity is no longer the company name....
I have heard talk of the Tekin 13.5 being faster than the DUO2's 13.6
Alex
hound_dogs_01 is offline   Reply With Quote
Old 08-26-2009, 09:29 AM   #4
thisguy2849's Avatar
The difference in the 2 motors are the motor with the redish colored sticker is an old pic of the original duo and the other is the new duo2. The duo 2 has more pull than the old motor and is also dynoed and tested with the dyno results posted to the outside of the box. You cant go wrong with either motor.
thisguy2849 is offline   Reply With Quote
Old 08-26-2009, 11:36 AM   #5
Armaan's Avatar
Cool, thank you. Also, are these rebuildable like the Novak Ballistic? Also, I haven't heard of the Tekin 13.5's being faster than the Duo2's or Ballistic's. Apart from trying all three, what's your take?
It would be great if manufacturers stepped up to the plate to provide consistent data, like the Nitro engine manufacturers, which provide RPM and HP.
Epic Duo2 13.5
RPM: 3402 RPM/1.0volt
Power: 7.62 watts/1.0volt
Torque: 116.8 Nmm
Novak Ballistic 13.5
RPM: 3300 RPM/1.0volt
Power: ?
Torque: ?
Tekin 13.5
RPM: ?
Power: ?
Torque: ?
Old 08-26-2009, 04:22 PM   #6
ALL new Duo 2 motors are dynoed and have the dyno results right on the outside of the box
Old 08-26-2009, 10:26 PM   #7
Tony Newland's Avatar
Trader Rating: 50 (100%+)
Epic Duo2 13.5
Torque: 116.8 Nmm
Power: ?
Torque: ?
Tekin 13.5
RPM: ?
Power: ?
Torque: ?
Nitro HP numbers are as phony as a $3 bill...... There's too many variables to document real world numbers on BL motors.... Batteries, timing, ESC etc etc etc. Buy whichever one you want.
The Novak Ballistics have the same internals as the SS motors... just with replaceable stators and adjustable timing. I've run Tekin and Novak motors back to back and my Tekins have more power and run cooler. The Novak with a 13mm rotor is alittle better, but still runs 30' hotter than my Tekin with the same gear/timing. I've also had some stout Speed Passions that were impressive
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 08-27-2009, 10:51 PM   #8
Armaan's Avatar
Ended up order the Novak Ballistic 13.5T. The key attributes that made me choose:
1) Ballistic can be rebuilt, and you can swap the stators to run in different classes, including modified, 10.5T and 17.5T. Stators are readily available and cost $29.99.
2) The sensor wire/harness is removable.
3) NovakTwo actively participates on RC Tech, so if I have a question, he can answer it.
