To go LiPo or not to go LiPo?
What do people think?
In my Kyosho ZX-5 with a Novak 8.5 brushless system.
Should I go LiPo?
Will it increase the top speed at all?
Torque is good with the Nimh battery, but I want more top speed (along with run time and the other perks of LiPo).
Should I go LiPo?
Hey Mate going lipo is a great change Makes your car lighter, increased run time and more power, what I like about lipo is being able to weight Your car in different areas and not weighing a tonne
Check out C ratings when looking into it.. try to get 25c+
Should definitely have overall more top end power aswell as more torque
If you want more top speed you will have to get a faster motor, or change your gearing. Go up one or two teeth on your pinion, just keep an eye on the temps.
If you want more speed from a battery buy a 7 cell NIMH pack or a 3 cell Lipo pack, and you will get more speed from the increased voltage, as long as you esc can handle it.
If you want to change from NIMH to LIPO and expect your car to have more top speed your not going to get it.
Lipo batteries will hold the maximum power through out the cycle of the battery. Meaning that NIMH batteries fade as your drivig, and you power will be slowly reduced until the battery is dead.
A lipo battery will run with out fade until, the lipo voltage cut off on your esc will turn the esc off.
The real benefit to using lipo in your car, is that its lighter, which, in essence make you faster. You will get maxium performance from the battery, which in essence will make you faster. There will be no fade in power, so through out the run, while NIMH batteries are fading off you will still have more punch than the others.
Actually I could have worded that better. It wont make you faster, it will keep you buggy just as fast from start to fininsh, so you will be more consistant in your lap times, and should have better overall performance and lap times.
Its worth switching to lipos in my opinion.
Thanks for the info mate.
I was looking around and stumbled across these:
http://www.hobbycity.com/hobbycity/s...idProduct=9436
Nearly everyone rates this battery big time, especially for the price.
It would seem Zippy have been doing flight LiPos for years.
Looking at getting two of these.
The ESC is only rated to 2 cells for Lipos.
Hobbycity lipos are great, just make sure to get the 25c or 30c lipos. The main difference between nimh and lipo that I see is runtimes. Not only are the packs smaller for more capacity, but they run strong up until the end of the charge. NIMH batteries have a "long slow death" each run.
Lipos are theway to go if you wanna race and be competative....thats it. It'll give you the same punch you get on your first lap with your nicd/nimh but the whole race. The are a lot lighter and the voltage is higher than nimh's. I think that you definataly should...easy as that. Once you get a lipo your nimh's will never see the track again.
You don't see any 1/8 brushless buggys or truggys running nimh packs, do you? No. It would be silly. They all run lipos because they are just better batteries.
Go out and get yourself some lipos man; You'll love em!
Forgot to add that nimh's are heavier and work your motor and esc a bit more than they would with lipos...Lipo's will keep everything cooler overall.
I just went to the Zippys from Hobbycity from good NiMH (for me - enerG 4600) was a huge benefit. The LiPos are tons better for driving, racing and make the buggy/truck we have lighter too. The lipos alone may give you more top-speed (less voltage drop under load, lighter car and more voltage under full load). However, you may bump up your pinion 1T or so at the same time for more top-speed. Do watch your motor temperature so that it doesn't go above 180*F or so.
When running a 3400 lipo on a brushed motor (less efficient) I'll definitely notice the fade as bad as when running 3800 nimhs because the motor is actually drawing max capacity near the end of the run. The higher mah packs have noticably less fade, but then so do the higher capacity nimhs. The weight savings is definitely a benefit for both handling and acceleration.
I like the fact that lipos store longer with a charge and don't need to be re-peaked before the race or discharge-cycled to maintain capacity. Less maintenance time = more track time!
