Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-03-2009, 06:04 PM   #1246
So nobody found a use for those little holes in the esc tray? I wonder if the Erevo MMM mount would bolt to that. If anyone has that check it out and let us know.
Caster Fusion pro SA 2200 combo Hitec servo on 4S- Ve8 MMM 2200 system on 4S W/ACE products. Hitec servo, KO EX1-UR 2.4.
Sponsor
GO-ENGINE.COM, GO TECH ENGINES FACTORY TEAM DRIVER
Caster Racing team member, Team terribles
malik is offline   Reply With Quote
Old 11-03-2009, 06:22 PM   #1247
BuggyKing's Avatar
They r mounting holes for the Tekin ESC.
- Rob's RC Hobbies Team Driver -
HB Ve8 coming soon .......
Definite Vacancy of the Cranium!
I just love Crock Obama! LOL!
BuggyKing is offline   Reply With Quote
Old 11-03-2009, 06:51 PM   #1248
marine6680's Avatar
So here is a question...
How is the Ve8 compared to the Hyper 9e? Handleing, jumping, etc.
Going to ask this over in the 9e section as well... Not to get a war started, but I figure its best to hear from both sides if you want to figure out where the truth lies. So no
marine6680 is offline   Reply With Quote
Old 11-03-2009, 07:12 PM   #1249
nv529's Avatar
Send a message via AIM to nv529
the erevo mount does fit real well using those holes but you'll need very long countersink screws to make it work.
Nick Vasquez
Hot Bodies D8Te, Ve8, AE RC10B4, Blitz
RC Product Designs
Dirt Burner Racing
nv529 is offline   Reply With Quote
Old 11-03-2009, 07:12 PM   #1250
mrramirez's Avatar
I was about to ask the same question. Anyhow, can anyone provide a list
of the lipos that fit this buggy, hard case or soft case. Thanks
Losi 8ight B, nova plus 4
Losi 8ight T 2.0, V-spec .21
Losi 8ight E buggy 2.0 stock
Hyper 9E, MMM 2650 combo
mrramirez is offline   Reply With Quote
Old 11-03-2009, 08:31 PM   #1251
fullsyzz's Avatar
Trader Rating: 17 (100%+)
I put screws in those two holes and screwed rod ends on the other side. Both the MMM & the RX8 fit perfectly between the rod ends and made a perfect way to run a zip tie over the speedo to hold it on the velcro.
fullsyzz is online now   Reply With Quote
Old 11-03-2009, 09:21 PM   #1252
Thats a good idea, I may have to steal that 1.
Sponsor
Old 11-03-2009, 09:37 PM   #1253
y2kgtp's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to y2kgtp Send a message via Yahoo to y2kgtp
Stupid question...but is there a good mounting point for the ESC power switch? I almost want to put one in the radio box....
Mid-Motor Speed-T,Mid-Motor xxx-cr, 2 Slash's, XXX-S, Mini-T, JRX Pro (still runs!)
Hot Bodies Ve8
y2kgtp is offline   Reply With Quote
Old 11-03-2009, 09:42 PM   #1254
i double sticked mine to the 45 degree angle on the right hand side rear corner of the chassis... the rx8 switch fits in there VERY nicely
TheRCshack.com << NEED X-RAY PARTS??? or anything else?
WTB speedpassion gt2.0
rclivechat.com
OWTKAST cpt is offline   Reply With Quote
Old 11-03-2009, 10:02 PM   #1255
y2kgtp's Avatar
I guess I coulda looke at HP page Interesting how the HPI relabeled MMM wires actually fit to the ESC......
Hot Bodies Ve8
Old 11-03-2009, 10:26 PM   #1256
Question for those running a Castle motor. What did you use to extend the motor wires an inch or so? 1" of 10G wire? Castle bullets as an extension perhaps?
Here are a few pictures of my fix for the MMM 2650, if you talk with CC they will send you the three color wires that you get when you send in your ESC for repair but you can get them by asking nicely. They are the perfect lenth and you only need to cut off the Tin end as they have the bullets on the other end.
Do not cut the orginal wires that come off the motor, just open up the bullets a little with screw driver and insert the bare wire ends of the others into the bullet and crimp them, with this done just add solder as it will fill in real well because the bullets are porous, then shrink wrap.
hotbodies-ve8-cimg1943.jpg   hotbodies-ve8-cimg1941.jpg   hotbodies-ve8-cimg1944.jpg
kboucher is offline   Reply With Quote
Old 11-04-2009, 08:20 AM   #1257
I bought the tork/2200 thinking it would work but had to get my wires longer too, I guess thats why they used a E-revo version in the pics I should have got that 1. Kboucher thats a good idea, mine has the "low wire mod" ends on it with the esc turned around 180 deg so I could use the wire router on the center diff and have the wires in the 1st battery strap= no movement.
Sponsor
Old 11-04-2009, 10:05 AM   #1258
the mounts are for the Novak HV ESC...
"thats not the smell of your tail pipes burnin, thats a little bit of shake.....and bake"
Team Hot Bodies (2008 Arrive and Drive Winner)
--Team Hot Bodies - Team SMC - VP Pro--
MikeGonzo is offline   Reply With Quote
Old 11-04-2009, 10:12 AM   #1259
y2kgtp's Avatar
You would think it would be for the MMM as they use a relabeled version in other HPI vehicles....
Hot Bodies Ve8
Old 11-04-2009, 02:08 PM   #1260
$Tmoney$'s Avatar
Trader Rating: 21 (100%+)
hey guys im running a mmm 2650 what should i gear it at? pretty large track also revalation raceway
Hot Bodies - murfdogg motors - Panther Tires
HB D4 Tekin RS murfdogg 13.5 - AE T4 Tekin RS murfdogg 17.5 - Hot Bodies Ve8 MMM 2650kv
Silent Assassins
$Tmoney$ is offline   Reply With Quote
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
