Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 08-13-2009, 10:38 AM   #31
My NeuEnergy 5s 3300 packs are 140mm long and no taller than a 4s 5000 pack. I actually like the layout, I just wish the battery tray were a bit longer.
This might be a good car to try out for the indoor season since I typically won't need to run larger than a 3300 pack.
XRay 808-E, Tekin rx8 & 1550 t8, 5s NeuEnergy Lipos.
Losi 8t-E 2.0, Tekin rx8 & 1350 t8, 5s NeuEnergy Lipos.
Check out www.hivoltagerc.com
Edumakated is offline   Reply With Quote
Old 08-13-2009, 10:46 AM   #32
kufman's Avatar
That is the problem, the high capacity cells (4300, 5500, 6500) are all 150+mm. Both my Neu 4300's and 5500's are 168mm long. I see the new Hyperion G3 cells are short too, until you hit the useful capacity size for 4S operation.
kufman is offline   Reply With Quote
Old 08-13-2009, 11:05 AM   #33
yzracer758's Avatar
My SMC 4s 5400 packs are 144mm long. Gonna have to break out the dremel out!
Hot Bodies | HPI Racing | Team Tekin | Diggity Designs | AKA | Thunder Designs | Kal-Gard Products | Thunder Power RC | Elite RC Products
Hot Bodies Ve8
Hot Bodies D4 WCE
yzracer758 is offline   Reply With Quote
Old 08-13-2009, 11:15 AM   #34
kufman's Avatar
lol.
wrrrrrrr (dremel sound)... BOOM!
Old 08-13-2009, 11:24 AM   #35
yzracer758's Avatar
Wouldn't be the first time I've had to call on it's duties!
Hot Bodies Ve8
Hot Bodies D4 WCE
Old 08-13-2009, 12:00 PM   #36
JSR
Originally Posted by Jube View Post
Well thats the problem. A 2000'sh motor spins too many rpms for 5s let alone 6s. Im not trying to be rude here but you are giving out false info.
As I said the CC/Neu on 4s was already difficult to control. The Neu 1515 is 1700kv I believe and on5s was even less controllable. I'm talking about motors powered to in the mid 30k rpms. Calculate the CCNeu and Neu motors I just mentioned to check rpms. That has been my experience and thepeople I know and seen with lower kv motors. You should read more carefully what the person wrot before saying they are wrong. I agree it is more efficient but from my experience too torquey since the same high voltage low kv setups run 15lb MTs.
JSR is online now   Reply With Quote
Old 08-13-2009, 12:09 PM   #37
Jube's Avatar
Trader Rating: 35 (100%+)
Originally Posted by JSR View Post
I've run the 2000ish kV motors in 4s, 5s, and 6s and they get progressively harder to control.
Actually I read it just fine thanks...
Jubal Dike
Avers Electric Co~BCE Speed www.bcespeed.com ~Team Tekin www.teamtekin.com Fastlane Graphix www.fastlane-graphix.com ~JCP RC www.jcp-rc.com ~AVID www.avid.com~Team Terribles
Jube is offline   Reply With Quote
Old 08-13-2009, 12:29 PM   #38
Originally Posted by KThatcher View Post
Thats just retail...
the street price should be around 299 to 329..
why does the HB website show it $200 more than the Nitro then? Is that not retail for the D8?
"Go that way really fast, if something gets in your way, turn"
Losi 8t 2.0E, EliteRC, Hitec Servos, Spectrum
Tekin, Reedy Lipos
DG Designs Graphics
DG Designs is offline   Reply With Quote
Old 08-13-2009, 12:31 PM   #39
Read RBMikes post.
Tekin, Reedy Lipos
DG Designs Graphics
Old 08-13-2009, 12:54 PM   #40
RBMike's Avatar
That's a truggy motor.
[/quote]That has been my experience and thepeople I know and seen with lower kv motors. You should read more carefully what the person wrot before saying they are wrong. I agree it is more efficient but from my experience too torquey since the same high voltage low kv setups run 15lb MTs.[/quote]
I've done both & your wrong.
My 6s 1400 is WAY more controlable than a 4S/2200 Castle new in a buggy. I addition I burn less than 1000mA in a 5 minute heat with a 2 minute warm up.
My actual experiance not something I heard or saw from someone elses experiance.
Sorry about the OT guys.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC,RCM tray
-EMBX6T,1700(Neu1512 3DF), MMM, 5S Lipo ,RCPD
-EMBX6,T8 1700, RX8, 5S Lipo ,Elite-RC,RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 08-13-2009, 01:28 PM   #41
JSR
That was in response to another persons statement that 2200kv on higher voltage is harder to control. I was agreeing also stating that low kv on higher voltage is hard to control. You seemed to have ignored the parts where I said the CCNeu on 4s and Neu on 5s, which are 32krpm and 30krpm respectively, were also very hard to control.
DG - I did see RB's post about his buggy. My direct experience has been different. From what I've experienced, lower kv higher setups are difficult to control due to the higher torque of lower kv motors. Perhaps because I like to go full when on straights which lifts the front more easily with lower kv.
RB - those are my direct experiences also. I drove the neu. Your experience is no more valid than another persons. Perhaps our driving styles differ enough to affect the behavior. But my direct experience is otherwise.
Old 08-13-2009, 02:11 PM   #42
Trader Rating: 16 (100%+)
Send a message via Yahoo to infanterene
Rbmike-
"My 6s 1400 is WAY more controlable than a 4S/2200 Castle new in a buggy. I addition I burn less than 1000mA in a 5 minute heat with a 2 minute warm up."
What motor/packs are you running? Are you happy with the MMM? What kind track? 20 min runtime must be no problem.
infanterene is offline   Reply With Quote
Old 08-13-2009, 02:16 PM   #43
pink_sleeve's Avatar
Trader Rating: 107 (100%+)
The current price on the site is full retail.
ARCS HOBBIES - DIGGITY DESIGNS
HIGHVELOCITY RACING - WIFE OF AMERICA BANKING
pink_sleeve is online now   Reply With Quote
Old 08-13-2009, 02:27 PM   #44
-J-
-J-'s Avatar
This is exactly what I've been looking for, as long as the balance is good [which I can't imagine HB releasing a buggy with less than sufficient balance], an aftermarket company quickly comes out with a better looking body [Can't stand those '57 chevy/batmobile fins], and follows in the footsteps of the D8 in terms of price and performance. I just can't spend $1,500 on a buggy. That's a new chassis for my birel.
I look forward to hearing reviews/comparisons of this buggy and the current e-buggy offerings.
Hot Bodies - Tekin - PowerPush - KO PROPO - eXpress Motorsports - JR - KillerKoncepts
-J- is offline   Reply With Quote
Old 08-14-2009, 07:23 AM   #45
yzracer758's Avatar
Yesterday I spoke to a good friend who drove the VE8 and he told me that the car's balance is fine and to expect good things from it!
Hot Bodies Ve8
Hot Bodies D4 WCE
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
baznz
Forum Jump
Powered By: vBulletin v3.7.6
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
