Losi xcelorin esc
#16
You can figure out your amps like this. Its the power your supplying the ESC
2200mah at a 25C rating is pretty much figured like this
22 x 2.5 = 55 amp
you can do this on lipo batteries and get the amp rating. take the first two numbers of the mah rating, or three numbers if you're pack is 10,000mah or higher, and then put a decimal in the middle of the C rating numbers. multiply the two and you get the amp rating. hope this helps.
So a 5000mah pack with a 25c discharge rate will have 125 amps
If you want to go faster then get a higher KV motor or go up to a 6S pack. Hell do both if you really want to get crazy....
22 x 2.5 = 55 amp
http://www.hobbycity.com/hobbycity/s...0mAh_5S1P_30C_
