best way to get tires off rims?
#31
Super Moderator
Trader Rating: 31 (100%+)
Nail polish remover is just acetone that smells better. For what a bottle of nail polish remover costs you can get 1/2 a gallon of acetone. Just an FYI if anybody didn't know.
#34
where do you get acetone and denture alcohol??
#35
Wal mart, home depot, lowes, in the paint department.
#36
cool, thanks og
#37
I just tried boiling them with different results, after boiling my tires for 10 min, I couldnt get it off so I put them in for another 10, then they started to go so It is just Time, but I wanted to go for another 10 but I have been doing it for 2 hours on like 5 pairs of tires so I quit for today. My hands are burned a little but Im used to it. I learned that it is better to do it in 10 min increments, boil for 10 min, then take out and boil a different pair for 10 min. let the other pair cool. It acts like the road, when its winter and it gets cold, everything is fine, but then it heats up rapidly, then it starts to crack, then cools down rapidly, it cracks more.
#38
Acetone the best way , does not effect the rim if it is made of nylon....
drop rim in paint can , come back 48 hr`s and the rim is nice and clean with no glue residue left behind....
#40
just a note. clay compounds dont play nice with acetone. they will be killed in process. so if ur in need of removing losi pink or JC gold. gotta go another route.
R
R
#41
I'll chime in on this...
I have recently started using the acetone bath and it works VERY well! I have done the boiling,baking and even using a CA de-bonder. Nothing works as well as the acetone bath. I went to home depot and spent $30.00 on the necessary supplies and have been able to pay for the cost of supplies with the reused rims on the first experiment. I have also started to de-bond my fellow racers tires for a lunch on race day I usually have to soak them for about 8-10 hours and they fall off the rim and most of the glue residue dissolves away. A spray of simple green and a quick scrub with the tire brush and they are good to go. I have only tried this on Pro-line, AE, and Losi 10th scale rims ( I am not sure of the plastic type ) and have had no problems, in fact there is one pair of Losi rear rims that I have de-bonded 3 times now. Acetone can be VERY nasty stuff so be very careful.
ALWAYS WORK WITH IT OUTSIDE!!!!! BUT not next to any flame sources, water heaters, barbeque grills ect. (It has a very low vapor point and is EXTREMELY FLAMMABLE)
Try to limit skin exposure, wear gloves or use tongs.
Here is a list of supplies...
one gallon acetone
one 1/2 gallon HDPE plastic paint bucket with lid (make sure to poke a very small vent hole in the lid to allow for expansion, but not big enough to allow evaporation of the acetone during the soak)
I just pour the acetone back into the can when I am done and clean out the bucket for storage. If you cut off the tire first you can get about 6-8 rims in the 1/2 gallon bucket
one gallon acetone
#42
sir, u can save the $ u spend by not immersing them in acetone. make a perch and fill the bottom of the bucket/pot with acetone. let the tires sit up on a perch not even touchin the acetone. cover and come back in a day or 2. its the fumes that eat the ca, not the liquid.
R
R
