Mamba Max in 1/8
#18
How long does it take Castle 2 get ur stuff back 2 u after u send it 2 them bcz its been a month since i sent it!!!!
#19
You need to put a bead of Shoe Goo around the top of the case and the circuit board. The screws that hold it in are to short.
You can run any 1512 or 1515 Neu motor, the Castle 2650, Tekin 4030 buggy motors or the Feagio L can motors.
I would recomend a Neu 1900, 2050 or a Tekin 1900 or 2050 on 4s.
The Castle 2650 would work well too.
#21
It should only take about two weeks unless they are in a cycle at the moment or had something wrong.......sence it has been that long you should call customer service and ask about your speedo......they won't bit.....and they will tell you what is going on and help you out........
#22
I got ahold of them and they said that they fixed th ESC but, there was something wrong w/ th motor(eventhough it ran????), so they scrapped it and now i gotta wait 2 more weeks b4 i get it!!!
#23
What motor was it that they scraped?
#24
Great esc been way more reliable than others.
To run properly pull red wire from rec connector,add bec,cap 2700uf 25v and 12v fan. I also added 10 gage wires, longer screws to mine. If you do not add the cap u will prob have issues. I use as much as 500mah a minute. 4s and 5s
It,s the real deal. info will help some1 doing search.
