Soldering Lipos....?
So I had this 4S pack that would get very hot running in my 8th scale. I decided to break it into two 2S packs for my Slash and SC10(much lower amp draw). I got one all rigged up, worked out well. So now I'm trying to get the second 2S pack ready. I have a very small metal tab coming from the second cell. I've tried about 4 times to get the lead to stick, and it just barely stuck. Any force at all, and it pops off. Is there some secret to soldering to those very thin metal tabs that come from each cell? I'm trying to be very careful not to heat up the cell itself...
Suggest you try some flux. Electrical (not plumbing) flux paste on the tab before soldering. And pre tinning the tab of course, maybe even with some flux. Agree on roughing it up as suggested. Both the roughing and flux are trying to dig through any surface issues such as oxidation.
Probably the wrong alloy to solder to. I've seen tabs that have been spot welded onto. Really hard to solder to unless you have a 1000+ degree Iron and silver solder. Do you have enough room to put forceps on to transfer heat? Litton has a flux that works with tough situations like this but hard to find.
you need zink solder... be sure to have a spare tip on hand and to do it outside...
http://www.cheapbatterypacks.com/?sid=1630096&pgid=bldg
They make this stuff in a tube called solder paste or something very similar. I have seen it used successfully a few times. As a matter of fact the packaging shows it being used on the tab of a lipo battery!
not all lipos have alloy tabs, some have copper.
remember, the soldering iron conducts elc. it may sound stupid, but I'v done it before...
That's what I thought, as I watched the solder just bead up and roll right off the tab! I was getting really frustrated, and even let my little bro try(he's done copper pipes and such). I'll see if I can either find the Zinc stuff, which may be a bigger pain than it's worth, or I can try the stuff in the tube. What was the brand of stuff you found with a lipo on the label?
Tis ME! I cut that Ugly Losi pack apart and got one setup. I even tested it yesterday, seems to work pretty well but now I'm thinking my motor is about done. That Titan just has no b-lls anymore.
I'd love to get this other pack rigged up, but the dang thing has some crazy alloy tab on it!
